De-badged, the driver/passenger doors. And burnt the paint! I'm hopeful it will polish out though.
Edited by M1ck3y
Had Krown rust protection applied today, along with their salt eliminator wash of the under carriage.
On 5/17/2025 at 5:03 PM, steelerdude15 said:
Not a mod, but did one of the best things you can do. I made my last payment today.
Congratulations! I just joined you. Finally all mine.
Installed Banks air intake. They sent out the wrong window though, so I’ll have to make one out of plexiglass.
I finally installed my Katzkins interiorMessenger_creation_496BF0DC-B574-4CB5-8DBA-9A008FC7D1DB.thumb.png.132387cc59dbe584de2faa168acfc0d8.png
Drained the transmission fluid.  Last time I did it I replaced the oem pan with the Dorman version with the drain plug.  Draining the fluid was so much less messy and easier.  I have drained it and replaced the fluid a couple weeks ago but since that only replaces about 1/3rd of the fluid I did it again last weekend.  The first time I overfilled the tank aand had to suck some out. This time I must have put back too little initally beacuse when I drove it afterwards the trans shifted veery hard.  I added some more fluid and it shifts smoothly again.  The fluid color on the seconstll looked pretty brown.  How many times do most of you drain and replace the fluid when you do this?
I replace a gallon now every oil change. Is that overkill? Maybe. 😏
All my vehicles had recommend extended drains on transmission fluid from the factory. Even my wife’s car with severe service schedule had 60k service. The worst was my avalanche even with the original owner changing the motor oil every 3K miles. He ignored the transmission. It had 165K when I changed it. With the exception of my wife’s Genesis changing the transmission fluid is easier than changing the oil. The Hondas have drains, the avalanche through the dipstick. I chose drain and fill every 30K miles, 3 times a week apart. I have no problem telling if the fluid is turning. The color and smell are apparent. My recent purchase a Ridgeline even though the owner was diligent with service. Had two drop and fills in 160K miles per dealer recommendation. He didn’t know better most people don’t. The fluid was slightly turning without smelling burnt. Now after 3 drop and fills, pink and fresh.
 Rewrapped my oem faded steering wheel, overall not bad for $50 🤷
You want to do mine next?
Lol it wasn't overall terrible to do, maybe 2 hours? But I took the wheel off the truck, impossible to do it inside
Where did you get the wheel wrap from?
    • How many miles were on the truck when you bought it and was there some form of oil change history generated through a dealer or an independent shop although not much would show up if the owner had changed their own oil. Just curious if it was a maintenance issue or if there was something off from the start, surely one would think the original owner would have realized it was using a lot of oil, its hard to go back in time and find out the true story of mysteries like this. Well hopefully the warranty company will go for it and just install a new engine, that would be the ideal outcome.    I still have so few miles on my truck as per not quite 9000 and will be changing the oil shortly which has around 2700 miles on it or so and its down so little on the dipstick from where it was at the beginning of this oil change that I could make the "claim" that it uses no oil but in reality would be a very small amount, less than a 1/16 of an inch. Just driving empty/not towing and easy driving so hard to say what it would do if it had a load behind it for oil consumption. So far very impressed with the very minimal oil usage.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
