I have tire rub on the plastic trim at the back of the front fenders I need to take care of. Heard it today backing out of a parking spot. Going to trim off the inside end at first. If that’s not enough, I’ll but the Rough Country trim plates and trim some metal.
Upgraded my iO5 to an iO6 with nav from WAMS with a new HMI.
Simple plug and play but I did have to steal a GPS antenna from the stereo I'll be putting into my BMW later on.
Works great and I now have road speed limits showing in my cluster (only for "known" roads, though)
  • Like 9
  • 3 weeks later...
Don't know how I avoided it this long, but I finally got the infamous shark fin antenna leak. We had an oddball warm day a couple weeks ago where it rained nonstop for two full days and I got in and there was water dripping on the parking brake and pooling a little bit on the driver floor mats.
Luckily, with there being so much years worth of content at this point on this issue, I pretty much immediately identified it as water trickling down from the antenna. Going to get a new one, clean up any corrosion, replace the old, and put a light thing of silicon to hopefully prevent this from happening again in the future! There was some minor staining in the headliner, but nowhere near as bad as when the third brake light leaked and can be easily cleaned up.
  • Like 3
Got a set of 2024 police tahoe wheels for my 2014 sierra, for winter. Just finished putting on the center cap decals. 20250130_135339.thumb.jpg.2678c330f8794932b2429797c1fae849.jpg
  • Like 4
  • 1 month later...
Cut the front fenders and made some stainless plates to pull back the liners and corner plastic trim. I now have about 1” of clearance but it still rubs the liner at the cab mounts. Need to see what I can cut/ bend there.
  • Thanks 1
Mane I cut as far back as I could 😂 on mine
Installed rear bilstein 5100s, performed oil change getting it ready to pull out of storage. During winter installed a light bar behind the grill, and made my own raptor lights. Ran wiring so it looks stock 👌
  • Like 4
This was an expensive month to say the least!
- Started to get noise from the rear brakes, which ultimately lead to new pads and rotors. These were on my list for a while, but the pads still had a bit of life left in them and I didn't suffer from any brake performance so I was planning to save it until later. I could not stand the noise and excessive brake dust though so that was enough to get me to do it, lol
- While doing the brakes, also noticed that there was an excessive amount of play in practically all the ball joints. This was another maintenance item that I was kind of hoping to do later this year, however, I just decided to do it. Decent amount of work and fairly expensive for the ball joints and control arms. However, I am happy with the final result and "hopefully" I won't have to worry about this for a long time.
- Also got new tires! I have had the current set of Goodyear Wrangler SR-A's since 2019 and about 53,000 miles (which is about the maximum life that these tires can go, to be honest). While I don't regret getting another set of these back then, I can also see why I (think) they were discontinued. The wear on these tires is just abysmal. I think they served their purpose well, but with normal driving and religious tire rotations I feel like the amount of wear and dry rot is just not acceptable. While I still do believe they look awesome on these trucks, I have reached a point in my ownership where my concern about performance and longevity kind of outweighs the aesthetics, haha. So I ditched them this time around and replaced them with Michelin Defender LTX M/S2s (based on the recommendations from these forums). My first impression: It is a great tire and I am looking forward to many miles from them!
Got a slightly used AFE Pro 5R intake from another member here on the forum over a week ago.  Finally got it installed.  Took a little time and cleaned the filter and the box.  Minimal issues with the install until I dropped the screw that secures the MAF to the air tube.  Dang thing landed on the skid plate somewhere that I couldn't find it or reach it.  Fortunately found a close enough match in my random screw jar.  Aside from the 15 minutes it took to solve that issue, everything was done in about 25 minutes.
I understood that these things tend to make the engine louder but I didn't notice any increase.  Also I am sure that this thing has doubled my horsepower.
  • Haha 1
I painted my tow hooks red, for my 17’ all terrain. Three coats of the red and three coats of the clear. Not to shabby for learning how to take them out on YouTube😂
That looks great. It's crazy how removing one of the hooks is such a PITA :)
Edited by UrbanRage
  • Thanks 1
Well, not today technically but over the past week and a half
Upper control arms
Lower Ball Joints
Inner / Outer Tie Rod Ends
Both front wheel bearings
Billet torque converter and trans tune as prevention rather than repair 😉
Thanks man, Yeah you ain’t kidding
I replaced my black hooks on my ‘18 with OE red ones last summer. Was definitely scratching my head on that decision for that one bolt. 🤪
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
