Took the truck to the dealership.  Got a check engine light, stabilitrak light and reduced engine power.  Called the dealer I bought it from and they told me they couldn't get it in until next week. Called another dealer and they said they could look at it tomorrow morning so I took it to them.
  • Sad 1
@14cris have you done the paint over Plasti Dip thing before? I’ve wondered if that works? Paint sticks to it and lasts? Any sanding/prep required on the dip before paint? And if it peals off like regular dip? THANKS
Painted the step inserts
Picture was a wet paint pic
Once it dried up it matched, i did a couple layers of plastidip first so i can peel everything off later if i want to
Never woulda thought of that. Granted I have a black truck but looks great man
  • Like 3
[mention=190938]14cris[/mention] have you done the paint over Plasti Dip thing before? I’ve wondered if that works? Paint sticks to it and lasts? Any sanding/prep required on the dip before paint? And if it peals off like regular dip? THANKS
Yes ive done it on just about everything
You just have to make sure the plastidip
Layers are enough so that they can peel off
Easily, i dont sand anything because thats the purpose of plastidip so if i go back to stock its all
Good again
Thanks, i want to paint the tailgate handle but its just so much work to take it apart and put it back together
Can anyone on here confirm if the 07-13 models have the same tailgate as our 14+ models?
Im ordering an ss style wing and the description says its for 2007-2014 but that seems kind of odd
On Autoparts warehouse website, they are NOT the same. 2007-2013 use the same but even then some had the easy open torshun bar assist and some didn’t. The WT has a different end cap too. 2014 started a new tailgate. Do I know for a fact? No, just a quick search on Google shows this information but it makes sense since that’s the typical grouping of like item parts per generation of said vehicles. I guess there might be a chance of the oddity out there but I think your suspicions are good ones.
Good again
Cool THANKS, I’m very familiar with dipping. I didn’t know if you ruffed up the dip before you shoot paint over it to help the paint stick to the dip but sounds like no need to.
I would guess that spoiler says 014 cause the 3/4 and 1 tonners were still the old style body in 14 they didn’t change till 015
Edited by wforrest08
Plastidip has that rough feeling anyways if you wipe your hand on it, ive never sanded dip before because i wouldnt want to cut down on the layers and it become hard to remove later
Ive always just painted over it and clear coated for best results works really good, just make sure you clean and prep surfaces before you dip it cause if you have any amount of moisture man plastidip comes right off after a while
That sucks!! Cause i dont want to trust this dealer and get ripped off but at the same time they have a really good rating lol
On 12/11/2018 at 8:01 PM, Crazyjoker77 said:
The mounts in the pictures you quoted are the Zroadz LED.  Not my truck, I can't see forking over 180$us+shipping for mounts.
https://www.zroadz.com/product/zroadz_z361221_hood_hinges_bracket_mounts_2015_2018_chevy_silverado_25003500_gmc_sierra
The ones I bought are just universal mounts SKTYANTS part# X001SF0L33 although now im seeing them all over the place amazon/ebay/aliexpress ranging from 10-30$ for a pair.  I did'nt know if they would work on the silverado's but at under 20$ it was worth ordering and checking out.  Wanted to see if they would even work and just ordered some lights now that I know they will.
https://www.amazon.com/lightronic-Universal-Bracket-Stainless-Offroad/dp/B073VK4FNG/ref=sr_1_3?ie=UTF8&qid=1544579620&sr=8-3&keywords=hood+mount
yes!! please let us know when you get the lights on...they look pretty secure.. this would be my route vs the brackets~.. what lights are you going with?
also.. i have the led bar wired up already.. i was thinking this route, and tap into the existing wire's of the bar.. that way i can put all 3 on using my homlink, how i have it setup now.
gonna look cool Crazy!
Well I’d call them. I’m not familiar with how that Wing mounts so it may work just fine. If they have a good rating then it may just be a simple shim or a direct mount. Email or call them, if nothing else you’d be doing them a favor for pointing out an error on their website and heck they may reward you for pointing that out with discount on any order?? Can’t hurt either way you go.
36 minutes ago, Shakeydeal said:
I had to google "Silverado wing". All I can say is........:lol:
Awe Shakey...that wing looks better than say...fender flares ? I’m just messing with you! Your truck looks bada$$ but it’s gonna take a lot more than a wing to make me chuckle...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
