14 Silvy Posted December 7, 2018 Posted December 7, 2018 Added a heated steering wheel after work this evening.Sent from my iPhone using Tapatalk 4
Enough Posted December 7, 2018 Posted December 7, 2018 (edited) Traded in my 2016 RCSB WT for a 2018 LT Crew Cab. I need to change my avatar picture but don't have a picture of the new truck yet. Edited December 7, 2018 by Enough spelling error
wahooper1 Posted December 7, 2018 Posted December 7, 2018 On 12/5/2018 at 1:57 AM, David solar said: Just got new wheels and tires finally 20x12 -51 offset vision rockers on 33x12.50 federal couragia and it rubs so bad And I did a NorCal mod on one fender then ran out of daylight so gotta do the other one tomorrow ?♂️ Sent from my iPhone using Tapatalk How much lift is on it? Im planning to put 22x12 -44 with 33s and do a norcal.
David solar Posted December 7, 2018 Posted December 7, 2018 How much lift is on it? Im planning to put 22x12 -44 with 33s and do a norcal.3 inch Motofab Leveling Kit stock blocks in the rear I installed it myself but my wheels are -51 offset so they sit out a little more but with the NorCal I undid everything pulled the liner back then cut the pinch weld out cut the corner of the bottom inner corner but make sure to leave the hole on the bottom for the bolt than cut the felt than beat in with a hammer the inner fender till it’s flush with the back panel than sprayed it with rust resistant black paint and trim some of the fender flare thing I have no rubbing at all but it’s super close tho I’ll get more pics soon The hammering part is gonna hurt but you just gotta push through it and get it flush ?♂️ Sent from my iPhone using Tapatalk
wahooper1 Posted December 7, 2018 Posted December 7, 2018 2 minutes ago, David solar said: 3 inch Motofab Leveling Kit stock blocks in the rear I installed it myself but my wheels are -51 offset so they sit out a little more but with the NorCal I undid everything pulled the liner back then cut the pinch weld out cut the corner of the bottom inner corner but make sure to leave the hole on the bottom for the bolt than cut the felt than beat in with a hammer the inner fender till it’s flush with the back panel and trim some of the fender flare thing I have no rubbing at all but it’s super close tho I’ll get more pics soon Sent from my iPhone using Tapatalk That's great i mistyped originally, im going with 22x12 -40 american force. I have 2" level front right now and am going to try to do enough norcal where i dont have to go to the 3" motofab. The angles look a little too extreme for my liking. VERY clean truck man!
David solar Posted December 7, 2018 Posted December 7, 2018 That's great i mistyped originally, im going with 22x12 -40 american force. I have 2" level front right now and am going to try to do enough norcal where i dont have to go to the 3" motofab. The angles look a little too extreme for my liking. VERY clean truck man!Thanks it’s taken a while to build it it’s my first truck but I honestly don’t know if your gonna be able to clear with a 2 inch leveling kit I am stupid close to rubbing but I Cognito control arms so helps there Sent from my iPhone using Tapatalk
Shakeydeal Posted December 7, 2018 Posted December 7, 2018 16 hours ago, Kurtj29 said: I love your build! Hope you don’t mind but I am thinking of using your setup as a blue print for my truck. How is the RC 5” going for you? I was also looking at the 4” Fabtech for MagneRide. What do your UCA’s look like. On the grill, I was thinking of blacking out my Denali grill or using the Elevation Edition grill I picked up locally. Here is a screen grab of a blacked out Denali grill. What do you think? The blacked out grille is tits! You should definitely do that, much better than the chrome....... Shakey
BigBadSierra Posted December 7, 2018 Posted December 7, 2018 I replaced my 2016 GMC Sierra Double Cab with this.. 3
SS502 Posted December 7, 2018 Posted December 7, 2018 41 minutes ago, Grjfer said: An attempt too quiet key rattle. I am going to steal this idea, thank you for sharing! I admit I am spoiled by the Push Start in my Honda and I can overlook the blind spot sensors not being integrated but the keys do get annoying on most of the roads around here. I thought about those silicone Key Fob covers but haven't acted on it yet, I have something very similar to what you have done sitting in a drawer at home.
Grjfer Posted December 7, 2018 Posted December 7, 2018 1 minute ago, SS502 said: I am going to steal this idea, thank you for sharing! I admit I am spoiled by the Push Start in my Honda and I can overlook the blind spot sensors not being integrated but the keys do get annoying on most of the roads around here. I thought about those silicone Key Fob covers but haven't acted on it yet, I have something very similar to what you have done sitting in a drawer at home. Kind of what I did hear. Just had the sticky back felt on hand so that's what I used. They do sell larger pieces, but as I said this is what I had on hand. Too bad GM didn't use the same stuff they have on the back of the seat belt latches on the front seats.
CajunFries Posted December 7, 2018 Posted December 7, 2018 I am going to steal this idea, thank you for sharing! I admit I am spoiled by the Push Start in my Honda and I can overlook the blind spot sensors not being integrated but the keys do get annoying on most of the roads around here. I thought about those silicone Key Fob covers but haven't acted on it yet, I have something very similar to what you have done sitting in a drawer at home.I used something like this for mine. Trim it all the way up to the key hole. https://www.amazon.com/dp/B01LW9P1GC/ref=cm_sw_r_cp_api_i_5sRcCbQ67HT7WSent from my iPhone using Tapatalk
SS502 Posted December 7, 2018 Posted December 7, 2018 7 minutes ago, CajunFries said: I used something like this for mine. Trim it all the way up to the key hole.https://www.amazon.com/dp/B01LW9P1GC/ref=cm_sw_r_cp_api_i_5sRcCbQ67HT7W Sent from my iPhone using Tapatalk How do they stick to the steering column?
CajunFries Posted December 7, 2018 Posted December 7, 2018 How do they stick to the steering column?Pretty good. Just make sure you wipe it down with some alcohol before putting it on. The one I have I’m not sure if it’s not exact one or not. It’s been a while. Sent from my iPhone using Tapatalk 1
STRMTRPR Posted December 7, 2018 Posted December 7, 2018 .. pulled out my dashcam hardwire kit and installed another one with a right hand USB plug vs the left hand plug my first one had 1 1
Register a new accountSign in
