So, I've been debating whether I wanted to do the rear bumper step light mod or not. I don't need the additional light for backing up, (I have 2" RC Pods for that purpose) but thought it might be nice for illuminating the step should I need to get into the bed at night. I ended up going ahead and installing 3/4" LED white pods that I tied into the reverse circuit. I did the cargo light / reverse light diode mod a while back, so whenever the cargo lights or reverse lights are on, the step lights will come on. Also added 3/4" LED red outer marker lights and tied them into parking lights.
That looks awesome. I have been going back and forth about types of lights/light pods to go with. I came to the conclusion that I want to go this route as it looks cleaner and doesn’t get in the way of anything. I didn’t think of using red to match the marker lights. I do have a tailgate light bar with reverse lights but still want to do the step lights. Which lights did you use? I found a few different sets of them on Amazon that I just haven’t pulled the trigger on. Again it looks great and thanks in advance.
Sent via my cellular device utilizing a chat forum thingy!
  • Thanks 1
Got my 5 inch RC bracket lift installed sorry for the shitty pics still needs an alignment new wheels and tires and cleaned up. Right now its sitting on stocks and 265/65/18.9caf8f92ac70826da6a52fddb846032c.jpgf6e6391af35e684703a0e61a6b100fef.jpg26a6b38d763b084efa9d350018bd0111.jpgf7ab5987edf30f4ea4fb30692a503f5a.jpg
Sent from my SM-G955U using Tapatalk
  • Like 7
Hardwired my dash camera and radar detector last night.  No more pesky wires dangling in my field of view and no more having to remember to plug in and unplug the darn camera!
Thanks TX LIMO, I'm very happy with the way it turned out. I purchased the LED's from Amazon. Below is a snip of the exact ones I purchased. Thanks again for the compliment.
Finally got around to adding some footwell lighting. Added some white to come on with the dome lights and some red for some accent lighting while driving and hooked both up to a dinner switch so I could control how bright I want them bdeb9fc23a266170fb7190f6bcf7ef62.jpg77d20272e0644a6e35276c9af84b9304.jpg
IMG_2983.JPG.b3f5edf94349be34ff43f3c2f50ad664.JPGIMG_2984.JPG.ae3a2e8783172e192abd2f27b7376acd.JPGIMG_3002.JPG.ecba1bafbe240e954abe53583e355fea.JPGIMG_2999.JPG.f5d6a11a3da7d428b29e04851c0ed7a0.JPG
Very nice
  • Thanks 1
Does anyone know what the clip goes to? It was in my dashboard by the light switch. I added what my panel has. I’m guessing either trailer brake controls since my 4wd lever in on the floor. I’m hoping it’s brake control so I can buy a new panel and not install an aftermarket one and drill that in.
Edit: forgot to add that the white clip has this written on it. (If it helps)
Sps/pa66-gf39
Mcd 17
31410
7ff9e2b26fd61630336b9d8bf0f55a01.jpgb86864fb146bc90bbf186b326b18ca23.jpg6c122d1a8fcc422e265efa5753ff7b62.jpg
I wonder if it's for the 4 wheel drive selector switch that's there on LT, LTZ, and HC. Your truck has the shifter on the floor.
Edited by dieselfan1
Yeah that was my second guess but since its on the floor i didn't think they'd run the wires since i doubt its simple to get rid of the lever set up
Just so you know at this time you can’t add the factory integrated trailer brake controller. It is not plug ang play several have tried none have succeeded... yet...
This thread hase several different controller options other than the standard knee banger set up.
Yeah i think i remember reading that thread a while ago but was more just curious on what it actually is
Not a huge thing, but vinyl wrapped the front/rear bowties. My white ‘17 Z71 had the black bow tie package and was one of the few things I enjoyed about that truck, so I figured I’d recreate it but refused to buy actual bow ties.
Do you have any pics of your setup?
On 6/15/2019 at 6:35 PM, lapoolboy said:
I'd go completely insane driving anywhere, following anything for 5 hours at 55-65mph! ?
I've done something similar for my son's high school marching band once but nowhere near 5 hours. It was just a short trip, maybe an hour at most and it drove me nuts! I was a good lane blocker when it came to lane changes for the buses though... LOL
They use the same harness for all the models to cut cost it just isn’t hooked up to the reader same with trucks without the trailer braking
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
