Agreed. It probly wouldn’t be an issue w/o a spare there, but with, I’m guessing that’s why they angle the bar down. On mine there was plenty of clearance with a spare.
2. Not to mansplain it (haha) but a sway bar tries to overcome body roll by lifting the inside wheel (opposite the body lean) to bring the body back to “level”. Which by definition means one wheel is actually less planted, not more, and subsequently there is less traction to the wheel being “lifted,” which also creates more potential for wheel hop during when starting off in a turn.
Love the discussion. Don’t want to clog this thread too much. I thought this link was a good read about sway bars, how they work and what type of handling differences you’re likely to experience depending on your overall setup. Like everything else, there’s always compromises and the key is choosing the system that works best for you.
I think the RAS system is really interesting too, thanks for sharing your experience. I had never heard of it before you posted about it.
http://speed.academy/how-swaybars-work/
“Using anti-sway bars to reduce body roll, to maximize contact patch consistency of all four tires, and to adjust handling balance front-to-rear continues to be one of the simplest and most cost-effective ways to help you and your car carve faster corners. You won’t see as much of an improvement from upgrading sway bars as you would from an upgrade that includes adjustable shocks and stiffer springs, but if maintaining civilized street manners while giving your ride improved handling characteristics for under $500 is your goal, you simply can’t beat a high-quality pair of adjustable anti-sway bars from a company with years of experience in the suspension tuning department like Eibach, Whiteline or KW.”
Agreed. It’s why I come to these forums. I think I know what I know, but there’s usually someone with a different perspective or technique and I usually learn something. Hahaha. And yes a lot of this is personal opinion. I’ll check that link out. Thx! And when I get the RAS I’ll post the install, so you guys can see it. Rock on, Holmes. [emoji1598]
Edit: Hahahah dude. That article had me at the general lee!!!
Applied Cerakote Trim Coat (Gloss) to all my exterior plastic trim. So far it seems to be good stuff. It doesn’t look greasy at all once it dries.
The directions say don’t get it on your paint or glass. I did. It doesn’t damage either of them but it’s an absolute b*ch to remove it. I had to use a razor’s edge on my glass and I haven’t tried to get it off the paint yet. Lacquer thinner doesn’t dissolve it nor does acetone. I haven’t tried anything else.
Also avoid your chrome and backup camera lens. When it dries it looks hazy on these parts but on the plastic where it’s intended to be used, it deepens the dark color.
Please note how long it last and if the plastic parts fade after use.
I use wipe new once. It has a stripping agent of some sort. It does seem to fade the cowl area and leave the rest same as before.
So these showed up. [emoji51][emoji51] putting them on Sunday [emoji1360]7d33486088b044ab2541e8cf3a2a8957.jpg
2 hours ago, slide187 said:
So these showed up. emoji51.pngemoji51.png putting them on Sunday emoji1360.png7d33486088b044ab2541e8cf3a2a8957.jpg
Very interested in your follow up posts.
It’s a super easy install, this time around imma do a video and I’ll post a link.
let us know how much it raises the rear. Ive seen a few mention that.
I was leaning towards airbags, or a sway bar..this sorta has the best of both in a way, and more. Only issue is price and availability in Canada.
Will do. I don’t remember them raising the rear at all on the Tundra, all they did was prevent squat when towing or hauling. So like the diff between having my ATV in the truck with and without these was it sat down less than an inch with, versus more than 2” without.
But I’ll take measurements with and without, and I’ll see if I can get the ATV up into this bed, but idk. If not I’ll just put it on the trailer and hook up and see that way.
Basically these will prevent/reduce the rear squat with a load and inherently keep the nose down under the same conditions thereby increasing handling. But yes they act like a sway bar, traction bar, spring helpers all in one.
I think i watched a couple installs on F150s, they said it raised them maybe an 1-1.5" or so in the rear. Nothing huge, but worth nothing.
I want to get something to help a bit with some pogoing on the highway when towing the TT.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
