Really thought it was silly to not have light under the hood. Nicely done!
I do a lot at night and with the hood up my carport light is blocked. I was really happy with the amount of light and I'm sure it's way more than GM would have come up with.
Sent from my Pixel XL using Tapatalk
Any reason why this setup couldn't work from the factory battery and not a dual setup? Is it too much power draw?
I only have my Kicker Amp/Sub connected to the factory battery and I have been wanting to do this mod pretty bad.
No reason at all. Be sure to fuse it. I accidentally contacted the wrong tab on the back of the switch and blew a fuse right off the bat. Didn't replace it till I finished my connections. I have a fuse box mounted on top of my second bat48543c729dfb145540d12df2d309606e.jpgtery.
I really need to quit reading this thread. Nicely done tens.
Makes me want to add my extra red top to my truck and add some under hood lighting.
  • Like 4
Just be ware if you have a 16 the battery tray is a place holder. I had to replace it with a true GM battery tray. There is another thread on that. Also the second tray doesn't hold the same size battery as the main battery. Made that mistake and had to return it. Mounted the fuse box on top with two sided tape and a bus bar with a relay that only provides power when the truck is running (fuse tapped a RAP fuse in the cab).
Easy to do, parts cost about $15, here is my set-up, I need to clean up wires at battery better though.20161112_122922_zps4awa41vj.jpg20161112_122916_zpswkzpc5zn.jpg
Edited by krzyd
You could easily add a small fuse box to the top of the main battery. Someone on the forum used the same fuse box I did and put it on the black cover of the main battery.
Well I decided that the cheap led fog lights that I got just were not cutting in so I purchased some Opt7 fluxbeam 5202 from amazon. So far I am extremely pleased with the results. I am running HID's in my stock projectors and the new fogs. Here are some pics of what they look like.
Before: (Headlights are before my HID Install in these pic's)
Inside the cab with parking lights and LED fogs only
After Opt7 fogs installed
31002374932_4a648f06b9_c.jpg20161120_173927 by Matthew Davignon, on Flickr
31002380772_0a75a29a24_c.jpg20161120_171236 by Matthew Davignon, on Flickr
Fogs Only
31110059516_f891cb273b_c.jpg20161120_171613 by Matthew Davignon, on Flickr
Fogs and Low Beams
31002377862_e6b0dd2919_c.jpg20161120_171435 by Matthew Davignon, on Flickr
Low Beams Only
31110063506_14d9d0eeb1_c.jpg20161120_171408 by Matthew Davignon, on Flickr
So, those Opt7 fluxbeam 5202's are HID fog lights? Plug and play?
What's your headlight set-up?
Fogs are led opt7 5202 fluxbeams all plug and play. My headlights are hids running on a relay to ensure they work. One of the hid headlights would not fire up without the relay from the battery.
LED reverse, cargo, and license plate lights. I noticed a huge difference with the cargo lamps. Not quite as much with the reverse ones.
Nfab Step Bars, Driver Assist Grab Handle, and McGard Tailgate Lock. Had my eye on the rear blocks but I need to take some measurements with the boat hitched up before I remove them.
The Nfab-grab handle combo is nice !!
Installed the frameless mirror today. Loving it!! :P
Without dimming
Dimming:
Without dimming
Dimming:
DASH CAM info please ?????
