2014 home projects
RyanbabZ71
  • Replies 106
The delta "touch" faucet is pretty nice tap on it and it turns on or off
Ryan
Overall shot 98% done
Ryan
Wow! You guys make me tired just seeing all your projects.
I have eveything piled in *my half* of the garage to do a makeover on one bathroom. Taking it down to the studs so the house general wants me to wait until retirement (88 days and counting). Waiting on her decision on what she wants for shower walls and it better happen fast! I WILL be taking the garage back, one way or the other......
I will be taking on a new project soon. Our home was built in 55. It had a breezeway that led to a seperate building. The previous owners (original) closed off the breezeway to make a pretty large sunroom between the two buildings. The seperate building is a single garage, office/storage room, laundry room, and another full bathroom. It also has the entrance to the basement in there. We use the laundry room at this point, but not much else. Wife hates how cold it is out there and I hate how expensive it is to heat it. Baseboard hot water heat. We found that with that thermostat at 50* it kept the oil burner going...A LOT. I was wondering why we wre filling up every month the last year and a half during winter. Construction is all cinderblock. There is insulation above, but not sure if any was shot into the walls. Stout building, but cold in the winter, hot in the summer... Plan is to pack out the walls, insulate, drywall. New carpet/flooring, new windows, and new doors, stand-alone a/c. Brother owns an exterior home remodeling company so I can get everything cheaper....hopefully haha. Plan is to make the sunroom an everyday room. I want to open the kitchen into it and use it more like a relax area. Kids can do homework and lounge....whatever. Project after that is the basement. It is ready to be finished with the recent completion of the french drain system!! After that, I think we are taking out some interior walls to open her up a bit, then a new kitchen. My forecast is 2 years, but I will be doing everything myself with the occasional help from my good friend who happens to be my nieghbor and talanted GC. This is my first home and I have loved it from the start. Nothing better then making is yours!
Just ran 100 feet of rg6 coax cable from basement to garage to hook my radio to tv antenna...... possibly a tv in the future if i decide to.
Sent from my LGL86C using Tapatalk
My dad wants to clear out the garage this summer, tear down the ugly 70's wood paneling, patch any holes in the drywall, paint the walls and then do the concrete renew stuff that makes the ground look like a showroom floor, should really make my new quad really stand out in there lol
My parents also are about to sign on a cabin up in WV about 5 hours from us as a vacation house. We would have 21 acres of our own, hunt club behind us, legal to run quads on the road, and Summerville Lake is 5 miles down the street, perfect for our little boat! The house needs work but they are getting it at a pretty good deal and my sisters BF said he will do the central air HVAC for free, we just buy supplies and help. We also will do all the other work ourselves, or as much as we can!
Next up, putting up an in-ground basketball hoop for my son. takes 270lbs of concrete and a 3 ft hole. Doesnt sound like fun :( Anyone have some dynomite?
@ryan Looks great dude! I'm almost done with my kitchen remodel myself just need to paint the walls. If I could make a suggestion, toss up a 1x4 on the end of the counter to run between the wall and the pillar stain it to match your cabinets and it would tie things in really nice.
No dynomite needed, just a couple buddies and case of beer!Sent from my LGL86C using Tapatalk
You have a backhoe don't you? :lol:Ryan
Not sure where you are exactly talking. Are you talking about the edge of the counter?Ryan
I rented one.... wish it was mine, I'd be makin some serious cash for side jobs.....
On a side note, a 3 foot square hole is not that bad. Last spring I dug around 3 sides of my house down to the footer to install drainage tile for the basement. All by hand. Probably 120-140 feet of pipe worth. Took a while but it was do-able.
Did you have clay?Ryan
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
