Anyone with a Z71 better check your gears
White14
I would look at mine but it's been at the dealer all week :banghead:
Waiting for new starter to arrive, which has been delayed by the weather down south.
Are they replacing your starter with a fool proof substitute - a hand crank? :lol:
Honestly, if GM cannot install a reliable starter on a 2014 $ 50k truck, they should go back to hand cranks.
  • Replies 75
Can't see, picture too small but check under the options and pricing on the window sticker and it should tell you what gear is on the truck. The first picture shows what would be standard features
Yes my window sticker says standard equip. 3.42. But options list says 3.08 installed. You have to look to the right side of window sticker.
Standard equipment should say 3.08 and 3.42 should be under intstalled options if equipped
The 3:42 was the standard gear. It also says that it had a 4.3L V6. The option is the 5.3L V8 with 3:08 gears if I'm looking at this right.
Yes you are looking right. All trucks standard with v6 everything else options
Yes you are looking right. All trucks standard with v6 everything else options Sent from my iPhone using Tapatalk
I don't understand the confusion people are having. It is pretty straight forward.
Mine read standard 5.3l 3.08 gearing, and in the options listed 3.42. I used the RPO code in the glove box to confirm the gearing before I purchased the vehicle.
You wrong here's the pic.
I didn't say I was right. I said "should". It is what was logical in my head. So the fuel mileage is optional. Nice to see a half way decent gear is standard
It probably depends on model for standard. My is LT standard V6 LTZ standard V8
Mine read the same way
342 standard and then in the options was 308
Mine runs well and has plenty o power
It has the trailer brakes and I hope a trans cooler for towing
Biggest thing I will tow will be a 12' camper and only a few times a year
Do you guys think I will be ok
If not could you not always change the gears to 3.42
I think knp is the trans cooler rpo. I have to double check. Just got to my soon to be ex-house. Spent my day prepping the new one. Ill look it up after I shower for you
KNP is aux trans cooler
But you could always upgrade like I did
