Ok here goes.. Good news Just received my console from Ebay Salvage yard console. $75 shipped Installed Drove down the road to program the HL and BANG in 5 seconds was programmed. Drove back to my garage---pressed the button and the door opened. Pressed again it closed. Success The consoles from Priority...... are faulty. Time for my next upgrade..
Did you happen to get the part # and/or date of the transmitter?
Just sent my two consoles back to priorityautomotive. So, I'm looking forward to getting my money back so I can do this! I'm wiring in my DL3 mirrors and auto dimming rear view with them as well. Added leather, heated seats and a full center console too. Removed the chrome bumper and have a black painted one now and added the chrome bumper filler at the bottom with tow hooks. The truck looks so much better inside and out. I just can't stop coming up with things to do. My next things are heated steering wheel, add passenger power seat and LED tails.
That's awesome. My next upgrade is install electric cutout y to a loud muffler on one side and the stock muffler on the other side. This way I can control the volume of the exhaust. and have dual exhaust. Going to try to use the sunroof switch in the overhead console to open and close the valve.
The date was 2015 on the transmitter. I don't think that matters. Good luck
Sounds like my mods :).
Alright so just an update. Got a new transmitter. Switched up part numbers to a newer model transmitter (23341161). Plugged it in and everything programs just fine.
Just FYI. I did go through a couple of other bad transmitters from different vendors. So I think part # 22944268 has some bad transmitters floating around.
AAAAH The sweet smell of success!
Not sure why there would be an issue. As long as you have power to the transmitter, it should be able to be programmed as it is a 'self contained' unit that doesn't require anything else to do with the vehicles computer system, ONLY the power plug is required. There is a setup that must be done, http://www.homelink.com/program/watchvideo Hope this helps.. I do remember having to reprogram it after I messed it up the first time.
Might be a little late but this is a link to setup based on your car ... http://www.homelink.com/program/process/1
  • 8 months later...
Has anyone had any luck with 22944268?  I bought a complete console off of eBay and I have having the same trouble mentioned here with 22944268.
Seller refunded my money from the console and told me to keep it, so I was looking to replace just the homelink module.  Looks like 22944268 is about $30 cheaper than the new part 23341161.
  • 5 months later...
For anyone interested doing this mod on a 2018 (or wanting the bigger sunglasses holder with Homelink), by deductive reasoning, I found the new part number to be 84083245.
  • 4 months later...
So just FYI for anyone interested in doing this.  PN: 84083245 is a direct replacement plug and play that took less than 5 minutes to complete the entire install.  I removed the stock overhead console and unplugged the main harness connector and plugged in the part number above and it worked.  I only had to switch out the passenger airbag light and put into the new part.  There was no additional harness to try and find a plug in for (this PN above included the harness for me along with the homelink).
I did NOT have the have any extra plugs to try and plug in or find a ground or power wire as some have mentioned previously as everything connected through the main harness.
Programming took 1 more minute and now having functional homelink, lights and passenger air bag light in less than 10 minutes.
I purchased on Ebay for less than $100.
This is on a 2014 LT without sliding rear window.  Ash grey in color.
Edited by peterlawl84
I'm guessing you sent that guy on eBay a best offer to get it under $100? What did you offer him? I need one of these
Edited by qwank
yea, i got 10% off. went back and forth a couple of times. Motown-partsman
  • 3 months later...
Great thank you
  • 7 months later...
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
