RECALL (3/28/14) Transmission Line Leak
Pathor
  • Replies 152
Mine was built 6/13 and it shows the recall and one of the lines under there will slide in and out slightly so I need to get it checked pretty quick. No leak whatsoever though.
Only 200 miles on truck just bought last week. All good so far otherwise.....But it is fire red in color !!!
Yotaman
Mine was built Dec '13 had the recall, took it in and had it fixed. No big deal.
@gmissed do you know if it can be fixed or do they have to replace parts ? Do dealers normally have the parts in stock if so ?
Not sure, I'll check the work order and get back to you.
mine was built 11/2013, I got the recall and dealer checked it this week while in for service work. Said they only have t tighten the lines if they are leaking or are loose.
Mine as built 8/13 and showed up today. Had an appointment for next week anyway.
RECALL 2014121
Recall Date 04/01/2014 Recall Description TRANSMISSION OIL COOLER CONNECTION Recall Letter
I didn't show recall when I typed in vin number, but I do if I log in to Chevrolet website.
Hi guys, just signed up for this site after lurking for awhile.
Anyway my truck was built 9/20/2013 and I just received notice
yesterday from OnStar diagnostics.
A recall notice has been issued for your vehicle. Your safety is our priority; see the Recall Reminder section for details on immediate action you should take.
Campaign #: 2014121 spacer.gif TRANSMISSION OIL COOLER CONNECTION
Not seeing any leak. Guess I`ll be taking it in.
No parts to be replaced. Comments on mine were..."inspect tranny cooler lines for being properly seated and no leaks." There is a .3 beside it so I'm assuming it took .3 hours to check - just guessing though.
