Just do what other people do when they buy a new truck, pay someone $500 to lather their undercarriage in goop.
I realized after I painted my frame that it was probably covered under corrosion warranty(which I still have remaining) not bumper to bumper, but I still would have rather done it myself right.
What I'll be doing is paying 99.00/year for an underbody oil spray
Here in buffalo we have a company called carwell, I swear bye there product, I'm not home to post pictures of my 05, but it was stunning and nicer then 99% of the 11-13 used trucks I was looking at which is why I ended going new, I will say they have been less aggressive with there spray as some rubber door seals have been swelling from the oil, so if u guys are doing oil baths research this, I removed all door seals and left the bottoms off, they trap dirt and salt begin there, scratch and rust out doors from the inside numerous used trucks I looked at had this issue,
Whats it have to do with it???? Everything, I'm not spending that kinda of money on a brand new truck, to scrape the frame, sand, prime, paint and clear-coat it.
That's absolutey crazy!
Ya crazy.
I checked my frame out and no rusting here and I purchased July of 14. Mine looks as good as new, Is this a northern issue with salt?
RT
Edited by 07Softail
No, you just probably bought one of the later built 14's. My december 2013 built truck had some rust on the frame when new. I told them about it and they took it back in the shop and sprayed what they could reach with some sort of undercoating. They just masked the rust with it and didn't really fix the problem. I am not to worried about it, just more of a cosmetic issue. If people think the painted frames on Fords are better then they should have a look at my 2012 f150 work truck, it covered in rust on the frame.
RT
Yes and not just road salt but magnesium chloride, calcium chloride, even beet juice (acidic). Sure you should wash the salt off but when your truck is a daily driver it's just not possible to keep the undercarriage clean all the time. Combine that with the mediocre wax undercoating that flakes off when you spray it with a carwash pressure washer and you're screwed from the beginning.
Why doesn't GM paint the frames (a good etch epoxy primer) then dip in wax?
I think the problem is two fold, residual oil on bare steel frame before wax dip, and wax thickness reduction on sharp edges. Look at the rear wheel well frame area where the round support tube pokes through the frame rail. the edge around the circle is most likely rusted.
i check the edges every oil change & touch up as needed.
Re the Magnesium Chloride, It's tough to remove.
Interesting read on Magnesiom Chloride effects:
http://www.summitdaily.com/article/20070103/NEWS/101030050
http://www.washingtonpost.com/local/trafficandcommuting/worse-than-salt-brine-sprayed-on-roads-will-munch-your-car-to-pieces/2015/02/22/b89294e6-b949-11e4-aa05-1ce812b3fdd2_story.html
It's difficult to remove without a pressure washer & soap. It is hell on electrical components, especially wiring.
IMHO, that's the job of auto makers to design & build a car that can withstand current road conditions.
Because it cost more. Both Ford and RAM paint their frames they give more of a shit.
Edited by Pinnacle
Like I said a few posts back, my 3 year old F150's frame is covered in rust. So much for painting them being much better.
If they start spraying them with the Bed liner spray they would never rust.
Ford/Ram/Chevy are all going to rust.
They don't want them to last more then 10 years.
Under coating and oil guard are a mess.
I just go under at the start of summer and re-paint everything.
After 5 years I still have a decent looking undersides.
The Ram I traded in my 14 Silverado on is painted. I only have 1000 miles on it compared to 8000 on the Silverado when I got rid of it. I will update after awhile and a few thousand more miles as to how it is holding up. The frame coating was the proverbial last straw. Add in the Jeckle and Hyde between the 2 service advisors I was dealing with and a piss poor area rep, I left GM after 25 years. Don't know that the Ram will be any better, but I will not buy a GM again. Ever.
Ram is fun to drive though, and even with 8 gears, the transmission always seems to know what gear to be in. Headlights work too, so that's a big plus.
Edited by Graphic
After my lift went on last month I noticed spots of my frame starting to rust around the edges of all the holes and at the edges of the steel and welds. My truck was built June 2014. I only have 8000miles and have had it 1 year couldn't believe when I scrapped some edges with rust and 4-5 inch pieces of the wax coating fell off as soon as I touched them. All the body mounts and shackle mounts were the worst. I sanded the rusty spots and any loose wax coating then brushed on Rustoleum Rust Reformer 2 coats. It worked great all rust turned black and the areas I brushed over the existing wax coating dried and hardened up the wax coating underneath. I am going to top coat with the factory GM wax paint coating. I know all oil based product soften the wax coating so I got the Rust reformer because it is water based. I am thinking of maybe doing the entire frame in a coat to harden up the existing wax paint.
I asked Krown about their process and GM frames in general.
Their reply below
"Thanks for taking the time to contact us. The factory coating will peel and flake off on it’s own but the application of our product will certainly accelerate this process. It is not necessary to remove the wax ahead ot time, but there are a couple options you can consider. You can have the application done and avoid treating the frame rails if you are concerned about the appearance of the coating that is on there. Alternately, we can treat the vehicle as normal. We would suggest you return a few months following this for a no charge touch up to the areas where the coating is peeling.
We have also attached some info from GM regarding this coating product."
I may wait for a winter or 2 before doing anything to see how the 15' frames hold up. I've seen videos/pics of new GMs on lots with rust underneath, mine has none at all so they did change something over the last 1-2 years.
The info they attached was a GM SB for wax frame treating, same as to what was posted here earlier.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
