Thanks for the comment, it rubbed the back of the wheel well liner which I have now secured with zip ties.
I'm real happy with the look.
I have a 2014 2wd and I think I am going to go with a 3" level in the front and 2.25" block in the rear. Should I go with a 1 offset rim or 14 offset? Tires are gonna be 305/55/20 terra grapplers.. im not sure if a 2wd and 4wd are different heights in the front so the 3" might give me that little extra to clear a 1 offset. What do yall think?
what are the rims? Or at least what are the specs on them? Are they 20x9s or another size? I think that makes a difference.
If ou do the 0 offset then you may have to do some trimming
They are the fuel mavericks 20x9. They come in either +1, +14, and +20 offsets. I figure with a 3" kit I should be able to do a +1 offset
285.55r22 Nitto Trail Grappler MT with 22x9.5 Fuel Maverick's.attachicon.gifIMG_3593.jpgattachicon.gifIMG_3595.jpg
love this setup. Any chance a 285/55/22 would fit with just a 2.5" level with 1" block in the back with + offset rim? Or would I need to stick with 285/50/22 to avoid major rub issues
Yes you can! Check out posts 1014-1019 of this thread
http://www.gm-trucks.com/forums/index.php?/topic/153363-2014%2B-Leveling-Kits
I have talked to 2 members with 22x9.5 rims with 34.5" tires. Both said no rubbing issues with the tires themselves but the rims rub at full lock
