If you do let me know what happens to you gas mileage. I took mine off the day I got my new wheels and tires and saw a dramatic decrease in gas mileage. Not sure if it's due to the new wheels and larger tires or just the removal of the valence or both. In my case I have put it back on to see if there is any improvement
I'd say I'm around 15-16mpg with my 275/65/20 on. What were you with it off
Could also be the larger rolling diameter actually has you going a few more miles than what your odometer says, but the truck can just tell you're burning more fuel ?
I went with 295/55R20s so the diameter is basically the same but perhaps it is off a bit. My 400 mile average was 15.2 mpg, now that the valance is on I actually haven't driven my truck since. But once I put some miles on I will let you know if I see any changes.
Valance makes no difference it's all in tires.... Lifts don't even affect it much Iv found its just larger heavy tires and winter gas and weather will crush the mpg
Sent from my SM-G900W8 using Tapatalk
Do you mean 295/70/18? What's your lift/level setup? Looks really good, btw.
Yea. It came down to the discoverer 295/75 and the TG 295/70. I read those numbers so much now I don't know what I've got. But I went with the Rough Country 2.5 level, zone 1.5 body and 295/70 TGs. I know some guys not using the 2" replacement blocks with the levels but I did. I like the factory look just a little lifter. Thanks though.
Jbutts what lift/level do you have?
rough country 2.5 level and zone 1.5 body
33X12.50 Toyo RT and ProComp 34 Rockwells 18X9... Posting from phone so I can't get the pictures to load, but here is the links.
http://i1097.photobucket.com/albums/g357/fernandoh87/IMAG0337_zpscohvha6w.jpg
http://i1097.photobucket.com/albums/g357/fernandoh87/IMAG0335_zpshzix3bne.jpg
Try uploading the pictures with your Wifi disabled. From time to time I run into the same issue and this seems to fix it.
Sent from my SM-G900P using Tapatalk
Do you have a lift on the truck other than it being leveled?
On +31 stockers? Are you having any rubbing issues in full lock position? What's your liner clearances?
Come 'on, man, we gotta know!
You'll be totally fine with this setup. I have a 2" kit and barely rub with 305-55-20's on 0 offset.
Hello, where are you rubbing? Just plastic? I currently have the 2.25" Readylift leveling kit. Looking to get some 305/55/20 on 9" wheels + 1 offset. After that I am hoping to move into a 4" lift whether it's with an additional 1.5" body lift or full suspension. But I figure I might just like the way it sits with the new tires alone, so I would like to know how bad it rubs. Thanks.
So I threw up my stats on the Lifted Thread already, figured I'd put them here too in case anyone missed it and wants to know. 2015 LT 5.3, 7.5 in. Rough Country lift, Rough Country skid plates, Moto Metal MO962 20x12, Federal Couragia MT 35x12.50 R20.
Edited by Glory-Hound
So I threw up my stats on the Lifted Thread already, figured I'd put them here too in case anyone missed it and wants to know. 2015 LT 5.3, 7.5 in. Rough Country lift, Rough Country skid plates, Moto Metal MO962 20x9, Federal Couragia MT 35x12.50 R20.
Those definitely do not look like 20x9. At least 20x10
Sent from my E6853 using Tapatalk
Can anyone running duratracs give me some feedback? I'm looking at possibly getting a set of 275/60r20, but wanted more opinions before I decided. I've heard a lot of good things from people I know, only really one bad review.
Added the 20x9 BMF Novakanes +0 offset. 33/12.50 Federals on a RC 2.5 level with the rear blocks424a0458998c6e819f09b619a24590ce.jpg
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
