Apparently I just have to txt them to myself to down size.
Your stock rims will have something stamped on the back of them like this. These are my stock 2014 GMC Z71 rims:
18x8.5Jx24
18 = rim diameter
8.5 = rim width
24 = offset
If you get +18 rims, your rim edge will protrude outward from your hub about .25 of an inch....or basically no difference from stock. You can get away with 0 offset (rim sticking out about 1" from stock) if you keep your tires to 295 or smaller and install a level.
To answer your direct question, you can install the +18 rims you want with any tire 285 or smaller without a level. 295 will most likely need a level. 305 will most likely rub somewhere and is the probably too large for anything other than a street queen unless you go to a true 4" or + suspension lift.
I've got 275s on stock +24. +15 is going to push your rim out about 3/8" from stock. I don't think you will see any noticeable difference in looks or trash kicking up on the side of your truck with that little of offset. 275s look a bit larger than stock, but no difference with speedo or power loss.
Nice thanks for that info i appreciate it
305/55/20 Toyo Open Country Rugged Terrain
20x9 +18 XD Heist
2.5 RC level
What offset? Any sway bar or control arm rub?
Edit: just saw they were sierra reps so +27, but do they rub? Lets see some more shots and if you could take pics of sway bar and control arm, are they flush with fender?
Here's some more pics. It will rub the back inside corner of the felt wheel well liners at full lock right or left. It's close to the sway bar but doesn't rub it at all. They are about flush with the fender wells. I forgot to add that this is with a 2 1/4" Pro comp leveling kit.post-54656-147837967665_thumb.jpgpost-54656-147837968637_thumb.jpgpost-54656-147837969379_thumb.jpgpost-54656-147837969925_thumb.jpgpost-54656-147837971428_thumb.jpg
Sent from my SAMSUNG-SM-G920A using Tapatalk
Here's some more pics. It will rub the back inside corner of the felt wheel well liners at full lock right or left. It's close to the sway bar but doesn't rub it at all. They are about flush with the fender wells. I forgot to add that this is with a 2 1/4" Pro comp leveling kit.attachicon.gif20161105_142305.jpgattachicon.gif20161105_142325.jpgattachicon.gif20161105_142358.jpgattachicon.gif20161105_142411.jpgattachicon.gif20161105_142652.jpg
awesome thanks man. Looks great
20x9 +18 XD Heist
2.5 RC level
I'm getting those same wheels but in all black and 295/55r20. Any rubbing on control arms or sway bar? Also looks great!
Thanks. I have a slight amount of rub on the sway bar at full lock in reverse. I zip tied the fender liner back prior to install.
Those wheels look BA. One of my favorites for sure!
Sent from my Nexus 6 using Tapatalk
Thank you
just a level?
Yes, just a level
18x9 -12 offset wheels with 34x12.50 BFG KO2
Method NVs
285/70/17 toyo at 2
Thats awesome! More pics!
My full size spare with Cooper STT Pro, white letters out.
Let me know thoughts on the white letters out, I like it. As soon as I have some extra funds, I plan to put Cooper STT Pros all around.
Edited by Rawyzf
Personally, when the look is aggressive enough (which those def are) I love the look of RWL.
I vote yes!
Any rubbing?? And what size lift??
Edited by vettecowboy78
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
