So I am looking to get new rims and tires. It's one of the only things holding me back from a 4 bds lift. I just dont know what I want.
I was wondering what people think of these rims? Not sure if I would go with 18 inch or 20 inch rims. But I do want to put toyo AT tires on them for sure. 33inch to be specific, maybe if they have ones that get close to 34 inch.
http://www.bbwheelsonline.com/grid-off-gd07-wheels-rims-black-anthracite-gray-bronze/
I am leaning to the brown / anthracite as I have an iridium truck and I think they would stand out. Or maybe the gray but that might be too dull. What do people think?
Sent from my Pixel XL using Tapatalk
Fixed my previous post. I put in the wrong freqs. Edited the post for the correct freqs
But any advice on tire pressure to use on the at2's? At 36 now
Sent from my Nexus 6P using Tapatalk
40-42 normal driving. Bump up when towing or hauling heavy loads
Best i could do before leaving work, then it started pouring down rain :/ love it though. 295/70/17 RTs with Method NVs. Stoked with how it turned out and surprisingly no rubbing, even with the little 1.8" the Bilstein's provide. Now i just wish i had 6112s and new control arms lol.C8BB12B3-9CA6-4FFE-86EC-DCCA7CAD6EE9_zps
99825CE0-D3B5-48E9-9B34-315B44010963_zps
8719E373-FBAD-4412-8E7D-577C0A678F76_zps
Hey bud, we've chatted before. How high do you think the 6112's will raise the front. I have the 1500's now and not as level as I had planed. Great ride but I think I will swap with the 6112's when they come out
20x10 -19mm Hostile Sprockets with 305/50/20 Nitto 420s for summer
Stocks with 275/60/20 Cooper AT3's
2inch level, neither set up rubs
I have an Iridium truck as well. I'd LOVE to see those bronze wheels on it.
Looks great. I think 18s with more rubber look better than 20s or larger. Good job for doing my homework for me.
Agreed . I've got the stock 18" wheels and actually like the more rubber route as well . Sure can't hurt ride either .
Going to be adding a 2.5 motofab level this weekend and considering these replica black 20s and Nitto Terra G2 275/60/20
Stock
Level with 275/60r20
And finally the journey is complete
6.5" zone lift with fox 2.0 shocks and 35x12.50r20
  • Like 6
My red 2015 has been traded(couldnt go as low as i wanted with 4wd). So here is my 2017 2wd with the same wheels and tires.
Does anyone know what time of year Discount typically runs the $100 off $400+ tire purchase?
Didn't want to start a new thread but I searched all over this one. Will the Method NV 17x8.5 w/0 offset with 285/70 BFG A/T work with stock height suspension (4x4 crew cab)? Or would I be better off going with the 275/70-17 BFGs for stock height suspension?
Edited by LFZ
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,803 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
