Hey guys. Every time it rains hard, I have drops of rain dripping from my driver's side visor mount where it attaches to the roof. I'm going to have the dealership look at it next service. I just had the 7,500 mile service done but forgot to mention it. I don't think it's coming from the sun roof. The only thing I can think of is the black roof mount antenna on the driver's side. I have included pictures I took today. Mine appears to have a slit in the rubber seal on the rear side of the antenna. Does everyone have the rear slit in the rubber seal? Has only else notice a leak in this area?
20140721 155048
20140721 155038
I haven't had this happen to me but I read somewhere in previous threads that someone determined the xm antenna leaks.
I noticed that same slit in the rubber seal on my truck XM antenna seal this weekend when I was washing it. I don't have water leaking in the cabin though (*KNOCK ON WOOD!). But yeah I'm not sure what's up with that gap in the seal. Seems like it's no longer watertight.
My 2007 leaked from the onstar antenna, and the sunroof, and some other seal I can't remember.
Good to see they addressed the issue.
I didn't get a sunroof this time around. Nothing I can do about that antenna, but will lose it, if it starts leaking.
http://www.gm-trucks.com/forums/topic/158522-water-leak-in-the-roof/
Sorry Chuck, didn't realize that you had already posted the link.
Edited by 14LTZZ71
Thanks guys for the feedback. After searching for a while, I did find the other link on here that talks about the leaking roof. I plan to have it looked at on my next service. From the posts above, I guess it could be the on-star antenna or maybe the windshield seal. Either way, hopefully my guy at GMC will get it fixed.
Thanks again.
my 14 silverado had same issue. gasket splits in rear and it poored in thru overhead console filling cup holders. new gasket and sealant to fix.
This is the first post I've found that described the issue I'm having. Mine is and 08 that I bought new, but it only has 35K on it and I baby it. Suddenly my headliner is soaked just in the overhead console right in front of my sunroof. Naturally, I assumed it was the sunroof but the drains seem to be clear of junk and drain just fine when I tested it. Also, most people report the headliner gets wet by the A pillars when the drains are plugged, but mine is bone dry there. I looked at the back of my OnStar antenna and there is a split there. I crammed some dum-dum in there for the time being since it's pouring rain and dark outside right now, but we'll see if that cures the issue!
(Of course I have a 24x28 shop, which is filled with my Avanti up on jack stands and my SL500 Convertible next to it, so the truck sits outside!)
I had the exact problem with the antennae leaking. I did not want the dealer to drop headliner to repair so I dried the area completely with compressed air and laid a small bead of clear silicone around the base. Instant fix and should last.
my onstar antenna was leaking from new (in Aug 2005, i was the 2nd person in NJ to take delivery of the new V8 Grand Prix GXP) and it was filling the map lights lol... not funny then for sure... That car also had a pinched yaw sensor wire, caught under a screw to the center console on assembly... great job "eh" (built in a canadian plant which won quality build awards lol...i can't win!) stranded with 90 miles on it.. no power at all..was shorting out... and then again at 250 miles
PS. my first all terrain (a new 2008 Extended cab) was allowing water to come in through a loosely fitted passenger front door.. used to soak the floor... I don't know why... i keep buying these GM's? I lemon law'd a 2003 Envoy XUV for AC that would go hot for no reason after the first start of the day (once it was shut down, upon restart AC would take several minutes of hot air blowing before compressor would come on.. replaced EVERYTHING to no avail!)
now i have a Sierra that oscillates or vibrates, take your pic, on the hwy
Edited by TonyAllTerrain
had same problem on my 2014. have the dealer check for any "dimples" or anything that might make the roof not flat. it took 3 tries before they noticed the dimples, flattened them and now no leaks from the onstar "shark fin".
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
    • It was all part of the tiny bit of fuel savings it goes towards what was mandated by the government. Much like cylinder deactivation. That was relaxed by the recent administration. All that doesn’t help the individual buyer. But as a whole helps the manufacturer to try to reach the previous ridiculous past mileage per gallon mandate. So yes it was mandated and added cost to the vehicle.
    • You do realize that auto stop/start...was never mandated by the fed...right?     EPA Says It's 'Killing' Stop-Start, and Here's What Automakers Have to Say   "Start‑stop technology has never been federally mandated, and the EPA’s recent action removes regulatory incentives associated with it rather than prohibiting its use."
    • Anytime the government mandates something, you can bet on it being absolutely senseless.
    • just logged my best MPG for one leg this am - drove home from the Denver Airport, 45 min drive - all freeway, lots of traffic so speeds were limited and some stop and go, got 17.7 for the ~30 mile trip.
