A possibility could be the Drive belt inside the rack, could have stretched during the steering wheel being turned with the key off, the strain on the rack with no power assist can cause that. But it’s kid of rare. No way to replace the belt either, a whole rack is needed. It would be great to have the trouble code. Maybe it just needs to be re-centered with GDS.
I will deal with it for now...Is there any chance the code will reset itself?  Would I be able to pull this type of code using my EFILive tuner? (I'll give it a try tomorrow.)
Thanks for all your help.
So finally got mine wired to a 10amp switched circuit.  It will now turn on for about two seconds and then turn off.  Anybody had this problem?  I can turn it on over and over for the two seconds so fuse is still good
Thinking higher amperage or just another circuit?  I ran with 16 gauge to pin 27 currently on drivers side fuse block
I think the original fuse for the heated steering wheel is only 7.5 amps
I hooked up my tuner which also doubles as a code reader.  It did not show any type of codes but I did a "clear codes" anyways.  That seemed to resolve the recurring "steering assist reduced" message.  I'm all good now  :)
Is there an ideal ground post on the drivers side?  I'm thinking my problem is coming from a bad ground.
Thanks all your help
Remove the door sill/kick panel, there is a factory ground bolt behind.
Don't you have the connector on the wire harness for the heated steering wheel.  The one that is taped over on a wire harness right near the steering column
I couldn't find the connector from the BCM.  I looked where everybody was explaining but couldn't find it so I just wired up 12v from fuse block.
Which by the way pin 27 is constant 12v...I've now changed to pin 37 and replaced with a 20amp fuse.  Pin 37 should be switched as stated in the service documentation.
For anyone interested, P/N 13574780 is the number of the mating connector for the heated steering wheel power and ground lead. It's about $10-15 depending where you buy.
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
