What is making folks excited and waiting for the 6112'?. I just ran across them on th bilstein site. I understand the coil is better, softer?
Well the shock body is a larger diameter so in theory it should do everything better, 62MM if I remember right. Spring made for the shock and have a great reputation on other platforms they are out for already.
Its a pretty big jump, think stock is 43ish and that size K02 lists at 54.5.
Stock size K02 is 53.1
. Yep, the KO2 is just heavy as crap combined with really high rolling resistance. I just switched them out with Nitto Terra Grappler G2 and got 3 mpg back instantly. Loved the look of KO2s but not enough for that mpg hit and the Nittos are way quieter. Problem solved for me. I don't do hardcore off roading anyway, just gravel roads.
I came to the same realization, I loved the KO's on my F150 when I bought it used. I got terrible gas mileage though and they probably played a large part Im finding out as I look into what tires are next for my Silverado. I just dont leave the pavement enough to justify getting the Ko2's. Ill pick up the passenger tire version of the Nitto Terra Grappler or Toyo Open Country instead. Weight is much closer to stock and both are still much better tires..
Any suggestions on a replacement rear shock for a Zone 6 inch lift? I called Bilstein and they couldn't give me an answer without knowing the specs on the current shocks I have now.
Just installed the 5100 bilsteins on 3rd setting ,absorbs bumps and road cracks a lot better not so jarring . the only problem I'm having is the drivers side is making clunking noise checked it and the center strut nut was not tight enough, tightened it some more not as bad but can still hear it. any ideas or info would be great.
When you say the ride is not so jarring is it just alittle better or maybe up to 50% better. Mine is really rough on potholes in town when going about 20mph. Sometimes it bangs the hell out of the front end. I cross a bridge everyday with a high approach and the front ends tops out. This is the only truck I have ever owned that does this. I guess Iam asking do you think the 5100's are worth going to would you do it again. I have been waiting for the 6112 shock and spring package for over a year and a half. I called bilstein a few days ago and said it would be 6 more months which is what I get everytime I call.
I had the Rough country 2" spacer and to me I noticed a big difference in ride. yes I would do it again. I bought mine through summit racing, they sent me a 50 off code and got them for 181 for fronts.
Thanks for the info
Sorry Ive been away for so long, between travel and surgery I have fallen way behind.
Per Bilstein - we are getting close! Hoping to have by September.
We have 10 kit's in the production que... the plant has been lagging so we have been kicking and screaming the last few weeks. I'm hoping it's just going to be a couple more months to get most of them.
Thanks for building the hype... they'll defiantly live up. The domestic full size 6112's turned out really really good.
I'll make sure to keep you in the loop.
So, just to clarify, you're running the 5100s on max AND 2" spacer? Aren't the joints in the control arms basically screaming from that or did you upgrade them?
Do you have any new deals on the 5100 set or coupons?
Edited by severado
I had the 2" spacer and removed them and added the 5100 bilstein on 3rd setting
I talked with a tech at Bilstein today about the 6112. He said it's really going to be a good set up. I asked him how the 6112 compared to the 5100. He said if you use your truck for normal use and some easy not punishing off road the 5100 would be just fine but if you use it hard off road and really heat up the shocks the 6112 would be the best. We talked awhile about the front suspension on the 2014 and up trucks and he said the problem is that it only has 3 inches of wheel travel to work with. This is why its taking so long to get the 6112 tuned right. They had a 2014 Camaro beside a 2014 1500 and the Camaro had more wheel travel than the truck. This is the reason the trucks ride like they do. This explained to me whats really going on with the front suspension and if you add spacers or blocks for lift it just makes it worst by taking away more travel.
I was told the spring rate on the 6112 set will be 50lbs less than the stock spring.
Edited by southern_sierra
    • Mediocre, how much did they lose on the poorly conceived EV strategy?   I wonder how much the stock price is being 'inflated' by all the buy-backs?   Cadillac literally looks like a brand without a rudder, no clear goals or product direction - performance or luxury? I guess performance because we can throw a small block in whatever we can and call it a day. Certainly not luxury when a Denali or High Country is reasonably cross shoppable. The Celestiq - no way - no vehicle can command quarter million prices when something wearing the same badge is on the buy here pay here lot across town.   Notice the 'base' Escalade doesn't even come with the 'leather-appointed' seating surfaces.   Hummer EV - fail Silverado EV - fail Sierra EV - fail Bolt/Volt EV (The most successful EV cancelled, restarted, cancelled, whatever its current status it)   Hybrids - none Sedans - none Medium duty - not anymore Minivan - none Coupe - none Convertible - none CUVs - 20+/-   6.2 Recall that landed squarely on the GMs highest seller - and specifically the fattest margin higher trims of the Yukon, Escalade, et. al. The most critical product line they fumbled big time. In the Escalade segment, are those buyers forgiving GM for a bad engine and patiently waiting for the fixes and dealing with the headaches? Nope, they dump them and go straight to the other premium brands.   In the ENTIRE GM portfolio how many aspirational vehicles are there? Corvette, Escalade (quickly being superseded by the obvious better value Denali)...   I posted somewhere else... what if Cadillac left the luxury game and became a performance brand similar to AMG or (gasp) Ferrari? Cut all the entry-level and base models from their line up and focus on the V-series or Blackwing or whatever they call it now. Of course, those would have the pre-requisite luxury and technology as standard equipment. This opens the floor for Buick to step in/up as the luxury brand (like they are in China), no 'performance pretenses' get rid of the 'entry-level' models with equally 'entry-level' power trains and become the Maybach to Cadillacs AMG. With those two brands effectively out of the way Chevrolet, the 'entry-level' brand has the floor to itself and GMC can take over as 'professional grade'.    Now each brand has a focus, no in-fighting, clear direction, and customer targets.   Just need to sneakily slide Corvette into the Cadillac brand and dump the vestigial script writing.
    • I can't get enthusiastic about the 1.5T (or the 1.3 or the 1.2), I won't drive a CVT. But the stupid things sell in volume.
    • There is a big difference in motorcycles and vehicles - nobody needs a motorcycle, they WANT one. That WANT is the most powerful force to drive price upwards.   I've hated every iteration of the Equinox, a prime example of GM laziness. It excelled at absolutely nothing, barely competitive by every metric. At least the latest generation looks decent.    I want to like the Buick Envista, but that pitiful engine plus FWD only is a BIG NO for me, I don't care how good it looks.
    • For as much hate as Ms. Barra receives on here, she sure is a shrewd businesswoman....
    • Love my new 2026 truck - even as a basic WT it's comfy, rides nicely, etc.   Encouraged by the 100K powertrain warranty.   2nd GM I've ever owned (1st was a 2000SLE with Vortec V6 - loved that truck.) Small question - maybe I'm missing it in the manual? - but I seem to need to press the unlock button first, in order to open driver's door.  (Don't care as much about passenger door.) RKIs: is there any mod/setting change, etc such that when I merely pull the door handle it just unlocks + opens? I have minor concerns about ability to exit regardless of electrical performance. (I'm a bit limited agility w/osteoporosis from hyperparathyroidism - big guy, age 62, range of movement etc issues.) Thanks, Bill San Jose CA
