They're working great, for a direct replacement using stock springs they are light years better than Ranchos. The 6112 should be awesome. The Toyota guys love them and say they're comparable to KINGS/ICONS
Sent from my SM-G950U1 using Tapatalk
Do we have any idea when they will release those?
They expected to date has come and gone. Who knows ?
Quick question..
2014 sierra crew cab
I got 275/60/20 Discoverer AT/3 and doing the Billstein level on top notch.
Can i get the tires mounted first before the shock install? Just wondering if it will rub hard untill i can get the shocks installed the next day or so.
According to the "Technical CSR" I've been emailing about these for the last few months, the current status is "They are due in anytime now, waiting on spring coating."
They always have one reason or another, but hopefully that is the truth. They have been due since last year. I will believe them when they arrive to our loading dock!!!
On 10/23/2017 at 5:24 AM, Ozer said:
Quick question..
U-Turns will be hard. But if its just for a day I think you will survive.
I just read a thread on the Bilsein bump that occurs after installation of the shocks. It seems the top plate does not get tightened down all the way unless you use a washer or spacer under the shock top nut. I have been having some noise in the front end since the swap over washboard sections in the road. I checked this afternoon when I got home from work and found my top plate loose enough to move. So I did some searching and found the thread mentioned above. The bad part about trying to correct tbis is you gotta almost stand on your head to correct it. Maybe not tomorrow night but by the weekend I will have done something about it anyway. I'll link the thread here tomorrow.
My Bilsteins set on the max lift were installed earlier this year so (living in the Midwest) this is first they've seen cooler temps.
On the expressway today the truck was really riding funny. Kinda like very small whoops so it felt like it was bouncing up and down really fast. ( I was going between 70 and 80 mph)Not like with out shocks.. It was very stiff feeling. I wrote it off as just being that section of highway combined with the trucks wheelbase.
Later I was on a totally different expressway and felt the same.
Anyone experience this? Would a spacer lift work better for ride quality with the shocks set at stock height?
Also Eddie 70, mine makes a light knocking/ rattle noise when going slow over terrain that makes the truck flex side to side. Nothing big.. Just driving across the yard will do it and I can't find anything lose.
I went out to the garage tonight when I got home and checked everything really closely. The top plate was VERY loose. The best way I found to tighten the bolt was through the fender well. Hold the wheel well liner back, rotate the shock shaft so you can hold it with a small crescent wrench. Tighten the 16MM nut on the top of the shock until it is tight against the top plate and no more movement is noticed.
Read this thread for pics.
I have driven approximately 175 miles since I did this the other day. This was the fix for mine. It may loosen up, but I can't imagine it would using the supplied nuts that came with the shocks. They are just a tad undersized and you have to use a wrench to run them down. However, if it does loosen, I will double nut it.
SO much better with them tightened down. The truck is almost quiet again and it has 92k miles. I am excited again!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
