I've read so many posts about the 5100s my head is spinning.  80% love them, 20% say they ride terribly.  Seems like there would be some in between.  Perhaps some Install error?  Maybe bolts need to be torqued when the truck is on its own weight?
Everytime I'm ready to buy them I find someone new who says they're terrible.
When have you ever been in a room and had 100 % of the people in the room agree on the same thing?
It’s $450 not a $4,000 purchase - and 80% (by your estimation) agree on the value of the 5100.  I’m unsure what else you need? A consensus?
Imagine if you applied that same selection criteria to the question:
should i I buy a Dodge?
should I buy a Ford?
should I buy a Toyota?
You’d never make a decision in life - if you’re looking for consensus from “peers.”
Edited by Oregon_GMC1500
Thanks to everyone who answered my questions with valuable information. I picked up the Bilsteins off amazon for 365 shipped if anyone is in the market.
For those that have changed the strut settings after installation, how difficult is it to adjust? I know its just a snap ring but I can't imagine its super easy to adjust.
You’re welcome and Good Luck!!
Photos are always welcome after install.
If other folks hadn’t posted images & advice on their setup - I would have been lost.
My point is there is a wide spectrum in results.  I assume something may be going wrong on the install or some defective part.
I decided to order them from 4wp.  $297 shipped for all 4.  I go back and forth on which setting I'm going to do, either the 2nd or 3rd (.75 or 1.25 claimed lift). Since I don't really want to mess with rear blocks and my truck has under 2.5" rake, I'll probably go with the 2nd setting and maintain 1.5" rake.
I'll be sure to post pics and a review!
I've used this style strut on a different vehicle, different brand.  You have to remove and disassemble the strut to change it.
If you got the set of 4 for $297, I don't think you got the height adjustables for the front. You might double check what you ordered.
Sent from my SM-G930P using Tapatalk
 Correct part numbers for the Bilstein 5100 for our K2's :
Front: 24-238304 (Adjustable)
Rear: 33-238319
 I have not seen these sold as a set of 4 so yes double check your order......
Rear: 33-238319
4wheelparts has a promotion on the package.  My understanding is the non height adjustable ones are 4600. I did call them to verify but they have to get back to me tomorrow.
I asked them if that promotional price covered the 5100s that fit my vehicle and they haven't gotten back to me in a week.
It doesn't, I tried to order them for my old truck last year and it only included "shocks" whereas the fronts are struts, so the deal did not apply. Cheapest I found them was amazon and summit at the time...Now I'm driving a 2017 and after one year of ownership I've had it with the Ranchos and I'm on this thread.
That's annoying.  I called them a few hours after I ordered and they said they couldn't find my order yet but they'll call me in the morning.  He agreed that the 5100's are height adjustable so it should be correct. Sounds like if it ends up costing around $375, I should still order them.
Back in page number 113 (i think) there is a phone number and a salesperson who's name is Alan mentioned in the body of the receipt. The price and his number are there, so perhaps make it easy on yourself. Parts arrived next day - and everything was perfect.
You guys were right.  Error on the website, it's for a truck with shocks only.  Straightened it out, paid the extra and I should have them soon.
4600s are the same internal shock, with yellow paint on the outside and blue boots/protectors.
Other than the silver look to 5100's, 4600's will do the same job if you are not wanting to level the front end.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 795 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
