When I installed my 5100s on the highest setting my toe was all out of wack.  I later installed a 1/4" spacer under the strut to get a little more lift and tow changed again but it was barley outside the factory range.  I got it aligned to bring it back within spec.
On 2/28/2019 at 11:12 PM, Yondu said:
They have been coming soon for 5 years.  We have had a part number for like 6 months, IIRC.  I called Bilstein a few days ago and they said very soon.
Minds will be blown if/when they actually come out
Did Bilstein offer any specifics or did they just say "very soon"?
On ‎2‎/‎28‎/‎2019 at 9:05 PM, bhales said:
so what am i missing about this part number for the 6112:D:smash:other than the fact no one seems to have ever had them instock. i went over some railroad tracks today and i thought i was gonna die the ranchos SUCK.
Ahhh, the infamous Bilstein 6112 shocks for our 2014 and up K2's
You will have better luck trapping a Sasquatch or sitting down to dinner with an Alien !
Most of us gave up on the 6112's years ago since their first reported introduction back in 2015.
Yes, Ranchos SUCK on railroad crossings and potholes.
Funny thing is, the 6112's are currently in stock for 2015 and up Tahoes and Yukons.
Many wonder if you can just order a set for the Tahoe/ Yukon and bolt them up to our K2s......
The GM parts sites list Silverado, Sierra, Tahoe, Yukon as fitment for the same spring & strut part numbers so wouldn't aftermarket be the same situation?
Sent from my Moto Z2 Play using Tapatalk
When I pressed for more information he said should be within the next few months, keep checking our site.
I'm not sure what the difference is between the Tahoe Yukon and Silverado Sierra are. It's very interesting they would release the SUV parts first as I would think there's more of a demand for the trucks.
At the price the Tahoe / Yukon 6112s are I would have expected a threaded body for adjustment on the truck & a decent top mount, not re-using the stock rubber stuff.
If you want threaded adjustment you are going to have to tap into the Coil-Over market and pay nearly double.
The point was, the aren't being used as a stopper, it's already sitting on them.
Going back to this bump stop situation, did you find anything else in this regard?
I had about 2" of travel showing between the shock & bump stop when it was assembled but no weight on it. I don't know how much the truck compresses this but I doubt there is much stroke left before the bump stop is contacted.
This might be part of the problem with the OEM shocks, allowing the suspension to bottom out easily & bounce off the bump stops.
I will try to see if I can check the gap to bump stop with the truck on the ground.
Ok, after typing the above, curiosity got the better of me. I cannot get the dust boot out of the way enough for a photo but it absolutely feels like the bump stop is sitting on top of the shock body & I can't move it up with my fingers.
Next step will be to take the weight off & see how much the suspension compresses with the truck weight.
If this setup really is allowing the bump stop to be partially compressed most of the time that seems very strange.
Mine is the same way.  I can't imagine it's any different stock, but I never checked.
Does this all suggest that they would ride better at 2nd or 3rd height setting rather than the first?
Mine is at 2nd stop, but yes that would make sense.
My guess is stock shock is most likely worse as it has softer damping so compressing bump stop more when hitting a bump in the road.
I'm at 1.4 lift, 2nd to top.  I assume the truck would ride after if the bump stop were trimmed.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,195 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
