40 minutes ago, MBSierra17 said:
Let's assume that the relaxed length of the spring is 13", and when on a stock truck, it compresses to 11" in the strut assembly down to 7" with vehicle weight.
With bilstein 5100, the strut assembly may only be at 9.15" (11-1.85 raised from the bottom), but the vehicle weight will still only further compress the spring to the exact same 7" with weight. Hence, modified ride height, exact same spring rate.
Please note these numbers are arbitrarily chosen.
Exactly!  The spring is compressed from 9.15" down to 7" which is only a change of 2.15" as opposed to 4" of compression (11" down to 7") in the stock setup because the spring is pre-loaded by the 5100's.  Same vehicle weight, less spring compression because of pre-load.
6 minutes ago, Sierra Dan said:
Many with the KO2's report a firmer harsher ride.
Especially with the E load ranges.
I'm certain that's where most of my rough ride comes from.  The 5100's are valved almost identical to the 4600's which I had on my old truck with P rated tires and that truck road a little better.  Regardless, I still like the rugged feel of my 2014 setup.
Still the same with p rated tires.
4600 and 5100 are built identically on the internal side other than a longer shaft for the 2" of lift.
I got my 5100's in this week and can't wait to get them on.  Putting that rears on myself next day or so and to my mechanic for the fronts.  They are cool looking right out of the box.  And again, always install the rears with the Bilstein logo right side up, regardless of boot down or up.  Called them myself this week to confirm that.
4W
Edited by 4weight
You're thinking about it wrong. In both scenarios, the starting length should be the full 13" of the non compressed spring. Then both scenarios end with the 7" compressed spring. The difference is the perch height of the bottom of the spring, and where you're temporarily holding the top of the spring (ie, assembled strut). The spring has a linear coefficient, and in both cases is supporting the exact same force. When it reaches the compressed length.
The spring does not get stiffer simply because you're starting from a more compressed state...
I feel I should clarify... As the two struts are assembled, the 5100s strut assembly is more load on the spring. Once vehicle weight is added, however, they both reach the same compression and are at equal levels of compressive force. The lift height is directly from the modified perch height, not the preload.
Edited by MBSierra17
4 hours ago, Sierra Dan said:
Have you installed these yet?
I haven't had time to get them installed and most likely it won't be until next weekend. The anticipation is killing me!
On 4/18/2019 at 11:01 PM, Randys Denali said:
I received my Bilstein 6112 47-273702 shocks today and you were right, these shocks are huge. I placed my order on 3/28/19.  The part number on the box has me questioning if I received the correct product. It looks like the right product, but the part number on the box is 24-242509.  Is that what you received as well?
I'm getting rid of the factory magnetic shocks because they're way too stiff and replacing it with the 6112's and 5160's in the rear. I'll be removing the rough country 2.5" lower spacer and installing the 6112's at the top setting. If my truck isn't level after, I may install a half inch lower spacer to even it out. I'm using the x-ineering delete kit to get rid of any alarms. I'm looking forward to a smoother ride. Those magnetic shocks are way too jarring driving on rough roads. I'm hoping to have mine installed by Saturday morning.
Thanks for sharing that you received your shocks.
After I saw you're post I check my part number and I have the same number as you,  24-242509. Did you confirm this is  the correct part number?
Thanks for getting back to me with that. Yes, per Bilstein that part is the correct shock number.
I tried to put the shocks on this last Saturday, but the shaft was too big to fit through the top mount assembly on the magnaride shocks. I spoke to the guys at Battle Born Off-road and they helped me figure out a solution to replace the top mounts with some KYB mounts for the SLT model. I should hopefully have them by next week and installed by next Saturday.
The anticipation is killing me too waiting to install my shocks...
Edited by Randys Denali
I got the same response when I asked about the part number. I was concerned there for a little bit. I haven't installed them. I got new mounts, covers, bump stops etc. for them so I can get them assembled and switch them out myself. Most likely it will be next Friday so I can get an alignment Saturday.
4W
They are monotube design. Makes no difference which way you mount. Boot up or Down. I tried both ways for about 1,000 miles and no difference at all in ride or handling.
My end preference was boot up. You can either flip the decal or remove it all together.
This makes sense.  I understand what you are saying now.  Thanks for the clarification and bearing with me as I worked through the logic.
Correct the orientation shouldn't matter from a performance standpoint.  But the reason they suggest boot down is to protect the main shock body from damage as it houses the guts of the shock.  Also, if any dirt or moisture were to get on the piston, it would flow away from the seal where the piston enters the main shock body rather than settle around the seal.  I'm not sure if it makes a major difference as Bilstein sells shocks that go in either direction, but technically the 5100's are intended to be installed boot down and for these reasons which is to protect the shock and make it last longer.  Do with that info what you will.
I believe the reason they recommend boot down is to remove unsprung weight from the suspension side of things.  It makes no real difference, but technically a small amount less weight will slightly improve their performance.
A damaged shaft is a bigger concern then a dent in the shock body.
Gentlemen,
              Sorry for the late reply as I've had these installed for well over 2 weeks. I've attached some pictures. The truck was completely leveled with the Bilstein 5100s at the highest setting. Front and rear it was spot on.
Some notes:
  • As others have said, take your old strut assembly somewhere to get them swapped. We had a hell of a time. We tried a floor mounted spring compressor to no avail, and the rentable threaded rod tool also. I ended up giving up and taking them to a local shop. Much easier, cost around 45 dollars.
  • The rear installation took about 15 minutes on a lift. Super easy as expected.
  • The ride has improved so much from the stock Ranchos. Those things are garbage. With the wider stance the truck feels much more stable as well.
  • This setup rubbed at about 3/4 to full turn, and reverse was almost un-useable. I went and bought the Rough Country Fender Trim pieces and broke out the angle grinder. This was much easier than I thought it would be, and now i have ZERO rub. Full lock turn, full lock reverse. Can't even tell I did it. I saw people doing the NorCal mod but for 17 dollars, the trim plates seemed like the way to go.
  • This setup is great. Rides great, looks great. I might go with a 4" Fabtech sometime next year. I'm not quite sure. I'm so happy with the ride quality i'm not sure I need to do anything different. I would only consider it to lift the truck up a bit more.
  • The next day I took my truck to get aligned as it was off pretty bad. I highly suggest getting this checked after doing the install.
2018 Chevrolet Silverado Z71 Midnight Edition
Tires: Nitto Ridge Grappler 305/55r/20
Wheels: Black Rhino Barstow Matte Black 20x9.5 -18 offset.
Edited by z71skywalker
  • Like 4
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 459 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
