4 minutes ago, Granite7 said:
I hauled 1200lbs of concrete tonight. All the bags were stacked to the rear of the rear axle, so this is almost the worst case scenario: 1450lbs out of my 1660lb max payload. I’m very happy with the minimal squat with my setup.
Front: Bilstein 6112 on the 4th notch 1.875”
Rear: Bilstein 5100 with 1” taller block (2.25”)
@Granite7, is this picture with the truck loaded with the concrete?
I've got my front Bilstein 5100's at the top notch, and am thinking about a 1 inch taller block as well. What block did you use? Any predisposition between, say, Ready Lift and MotoFab or any of the others?
Some have complained that these are tapered, but with the front raised almost a couple of clicks, I guess that's to align the drive shaft better...any input with your setup? I hope not to have vibrations at 75mph, as I had a very nice riding truck when it was totally stock
[mention=205292]Granite7[/mention], is this picture with the truck loaded with the concrete?
Yes, that is loaded down. I was very happy to see it almost level!
I used the ReadyLift 2.25” blocks. They’re not perfect, but I felt their block design was stronger than other blocks on the market. I did have a problem where the bolt head from the spring pack didn’t want to seat into the dimple in ReadyLift’s block. Between the neighbor and me, we had the tools to mill out the pocket to fit.
I worried about the taper also, but I haven’t felt any vibrations or had any noticeable axle wrap. I like acceleration, but I’m old enough to drive like an adult. Speed limit here is 75, so 80-85 is not unheard of. Ride quality didn’t diminish as far as I can tell.
That looks really good for holding 1200. I'm with you, I dont need to go terribly fast anymore, I just know it was steady as a rock no matter what speed I brought it up to, and I'd like to keep it that way, as stable and steady as possible. So I'm optimistic
Thanks
going to bookmark this setup for when my shocks eventually need replacing.
this is perfect IMO
On 7/20/2020 at 11:55 PM, Sierra Jon said:
FWIW I ran helwig 987 heeler springs on my last K2 and it raised the rear up an inch and stiffened up the ride a little. Another option...
Sent from my Pixel 4 XL using Tapatalk
@Sierra Jon , is that enough to qualify as a heavy half ton or would you need the leafs fully swapped out with the 5 from a 2500?
[mention=138501]Sierra Jon[/mention] , is that enough to qualify as a heavy half ton or would you need the leafs fully swapped out with the 5 from a 2500?
No. That wasn't my intent either. I just wanted to improve the ride height (keeping the truck level) when towing my travel trailer.
There's other limiting factors like GVW and brake circumference that play into the HD payload.
Well I'm wanting to know a professional shop's opinion (anyone's experience, really but for sure a 4x4 shop) on whether the removal of the 1.25" block and replacement with a tapered 2.25" block is actually a good idea on these trucks if I've just installed Bilstein 5100's at the top setting at the front?
Is the drive shaft angle within acceptible limits as is, or am I looking for trouble down the road if I dont install 2.25 inch blocks with a taper?
I've got a 5 or 6 thousand mile road trip - Boston to Big Sky and back- coming up in October and I dont want to cause an issue before and certainly not during that trip.
Sorry if some of this ground has been covered. I wanted to read this whole topic first. Git to page 40-something and went plaid. So I decided to cut to the chase
On 7/23/2020 at 4:00 PM, Battle Born Offroad said:
No, but what can we help you with?
Please see my question in the post immediately above this one, if you happen to know.
Thanks
Pretty sure you will be fine either way. When I got my truck it already had a 2.5" RC lift in the front and stock block still in the rear. I replace the junk Ranchos with 5100s all the way around and added a MotoFab CH-2R 2" rear lift block because I didn't like that the rear was a little lower than the front. I've had no issues with how it drives with either rear block and it's been up to 130 mph with the rear lift blocks in.
What upper control arms are you guys running? Suggestions, recommendations? I'm about to pull the trigger on some 6112's on the 4th setting and 5160's for the rear.
I have those shocks, 6112s on the highest setting, and I’m on stock control arms on my ‘15 Sierra NHT. They’ve been on for almost a year now.
Do the 5100s have a "0" setting? I'm still trying to wrap my head around if they are for trucks WITH a level or can level themselves, or do both in combination.
I have a BDS 2" level that I am happy with. Truck sits perfect and drives fine. I have no interest at all in any extra added height, but I'm looking for some good shocks to tow with. The 4600s sound fine to me but they are for stock height apparently. That's fine for the rear, but again, I'm 2" higher up front. Does this imply that the 4600s would be too short and top out a ton with a 2" up front? Will the 5100s work in front for me without adding any more lift?
Since I'm here, how do the shocks lift anyway? Valve the fluid up and put all the pressure on an internal spacer/solenoid that provides the lift? I suppose I could delete the BDS and just do 5100 but I'd imagine the shocks would last longer if they weren't artificially trying to support the weight of the front end up. Maybe I have it all wrong?
Not looking to do any off-road. Just bought a max GVWR 7,000# travel trailer and looking for ideas to help keep it planted where it should be.
Thanks for any tips/info.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
