28 minutes ago, revrnd said:
Is the Alaskan Edition a Sask' dealer option? I've seen Cheyenne & Kodiak 'packages' here in Ontario.
No it’s on the Chevrolet website as one of there limited edition models, so it’s North America wide.
My 2017 2500HD Z71 SLT
-Fully loaded-only difference from a Denali is the decal, lol. Def gotta upgrade the rubber B4 winter.
Edited by hydroguy
And the seats (10 way vs 12 way), and the dash display.
Gorgeous truck.
Picked it up 10 days ago, traded '17 NHT 6.2
Hooked onto the travel trailer and headed to fla.
1600mi on it, what a great truck.
Where abouts are you staying in Florida?
Sharp truck!!!
11 hours ago, SierraHD17 said:
Here is my bucket of bolts.  It's a 2017 2500HD gas pot..... and probably about the weirdest optioned SLE ever made.  I'm good with it though!
what makes it so unusual?
Sharp truck!!!
Port Orange
4 hours ago, steinb3rg said:
Chasing elk in Colorado.
Nice! I'm jealous! I've been out there camping/4-wheeling many times, but my work schedule hasn't allowed me to do any hunting. What part of the state?
We are in Gunnison until this coming Friday trying to get it done. Talk about a learning curve coming from below sea level in LA. Seen a couple but nothing close enough to get to yet.
Plenty cool truck picture opportunities though.
Seems like its always dark or snowing when I get a chance to snap a picture of my truck.  Just did a quick 1300km road trip on the weekend and she ran like a champ.  Definitely likes the fuel, but you gotta pay to play.
C2ED2ACB-6ED6-428F-88AA-EA9B4F912815_zps
FAD0342E-BAD0-4123-8CE2-6DF9888E41D8_zps
1691711C-99A3-4BE0-9CE0-AF32D81BE7C1_zps
Awesome! That's a beautiful area! I've ridden 4-wheelers all around the national forest NE of Gunnison in the summer time. Good luck with the hunt! I'm sure the snow makes hiking even more of a challenge!
On 11/6/2017 at 9:34 AM, SierraHD17 said:
Choice of options.
I'm intrigued...
I want an SLE with a tow package, preferred equipment group, Bose, and carpet delete. Leather would be nice, but not sure I want to spend the $$.
Love your color. I think your pic made me decide on Blue vs. Red!
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
