2014 Sierra steering wheel clicking noise
Joeyjo
I've had my all-terrain for 4 months. The second day I had it, I had to bring it back to the dealer and have the exhaust replaced because of a bad tuning valve. A month in I had to fix the drivers seat with hose clamps. Now I have a clicking noise in the steering wheel when turning. I've owned 9 GM trucks and this will be my last. I currently have 6700 miles and barely get enough time off to keep up with all the recalls.
The seat would shift and make a clicking noise while turning. Have not had a chance to get the steering will looked at. It just started. It takes a couple weeks to get into the dealership. They're backed up working on recalls.
not sure if yours and I steering problem is the same but GM just repalced my entire steering wheel assembly due to some broken parts. 2 day job .
Not exactly sure what that is but if you want I can give you word for word on the service reciept. ( its at home)
The clicking was only heard when car was not moving . Either left or right.
Mine seems to be working better now.
Mine also clicks or pops when parked and I turn the wheel. Was hoping for a easy fix but sounds like this will be a dealer issue.
  • 1 month later...
I have a 2014 with a leveling kit. The Rack has been replaced Twice . The light clicking noise in the steering column is from the gear box in the Rack. It's been back to the dealer approx. 15 times.
was it covered under warranty? did they give you any crap about the leveling kit maybe causing the issue?
I have the same problem but am worried they wont cover it since i have a leveling kit on.
Shit just another thing to add to the list to worry about happening. I have a very annoying rattle that I thought was coming from my steering column while hitting little bumps, but I couldn't find it so I'm thinking its coming from the steering wheel. Tried taking the air bag off to check, but I cant figure out how the spring clips work on the back.
ya and its a very unsettling one... not sure why they recalled only a handful of these to correct the issue. steering seems pretty important
Maybe it was only certain batches that were known to go defective?
yea i think you're right. looks like the assemblers werent tightening the tie rod nut going into the rack, which is probably a separate issue from what we are experiencing now. either way its pretty unacceptable in my book and i hope they cover it.
6,400 2014 truck were effected . This is what has been replaced to date . Shifting seat . (2) steering Racks, (1) pair of struts due to clunking when turning. Rear springs still drive me crazy with the popping. Left front clicking noise still comes from both wheels on the driver side( I think it has to do with traction control) paint chipping of in small 1/8 circles. A whistling noise that come from the front of the intake( not the direct injection) and now I think the left rear axle seal is leaking. One thing after another with this truck!
Wait until you get more miles, Mine has over 70,000kms and Ive had a lot done too, including leaking valve cover, transmission oil cooler line and engine oil cooler line.
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
