There's a 1" block between the axle and leaf springs and I believe you're able to remove the blocks without any problems. Honestly, I wouldn't want a truck perfectly level anyways, well that is if you actually use the truck for what it's intended for. Once you hook a trailer up to it or put any real weight on a perfectly level truck the rear will then be lower than the front so it will look bad. If it was me I'd keep it how it is. I was going to put a level kit on mine but since I have so much weight in my toolbox it actually lowered the rear enough to be a little more level while still having a good rake. I wouldn't mind a full 4" suspension lift though.
I have airbag suspension installed in the back for when I tow boats or the occasional toy hauler.
You can contact rough country and special order the 2.5" level kit. Its your 2" blocks and .5" spacer on top of the shock, but instead of the 2" rear block that comes with it, ask for a .5" block or remove the block all together.
I would prefer some rake though, just in case you have to haul something or tow something
I'll have to look into getting the 1/2" rear block. Maybe they can sell me the rear block and the extra 1/2" spacer in the front since I already have the 2" block in the front
  • Replies 68
I would install the RC strut spacers, have the truck realinged and you should be happier.
Every truck I have seen with the RC 2.5in. level was completely level afterwards.
E196A28B-2853-4392-8C98-AEC8A030AF98_zps
383DA1D0-1624-4F4A-847E-DB41BDEA89F1_zps
54C537A3-2F6B-4907-8D0D-FCBCBF30BF31_zps
FADE9CD4-F333-4C43-8F5C-E5CB04CD7B1D_zps
Ask and you shall receive lol. I'm always taking pictures of my truck, but I found myself trying to find the best angle to not show the rake. I would really prefer the leveled look with no rake, so I'll have to look into getting the extra 1/2" from RC
Your truck looks fairly level. I think you are looking for the optical illusion of level. Why don't you remove the lower front air valence. It's held on by a dozen bolts. And you can do it yourself
This will make your front end look higher
These pictures were taken a couple months ago. Since then I removed the air dam and put a 20" light bar in the black plastic area on the front bumper.. Still not completely satisfied with the stance though. Don't get me wrong, I love this truck, but I don't want any rake, that's why I installed the airbag suspension.
Thanks for all the suggestions guys, I didn't think I would get replies this fast when I put this post up this morning at work lol
Why would he install shackles when all he has to do is remove the rear block?
Was just a suggestion. Didn't think of it at the time
Just put a 6" lift in it and be done.
I would love the look of a lift, but I don't want to ruin the smooth ride I have now
The 8" lift kit i had on my truck didnt change my ride, all it is is a strut tower to lower the strut and a lower corssmember to move your control arms down farther, your still using the same strut, and the rear is only a lift block so the ride stays stock
i ordered the RC 2.5 inch level kit..from their site it includes the lower part-the upper spacer part..and replacement rear blocks..
you can buy & just add the .5 or whatever the top space is if your not happen..look at the rough country site believe its available separate
Do those tires rub at all anywhere? What is the backspacing on those wheels? That is perfect stance IMO. Love it.
I agree with some of the others' comments here - it looks great. And I also want to know how those Nittos are doing in terms of fit - no rubs, any mods to the wheel well or anything else to make those donuts fit?
I just took my 2.5" RC lift/level off. Let me know if your interested.
I think the truck looks perfect as is.
Then again you'll never get everyone agreeing to one thing. It's pretty subjective.
So that's my vote. Perfect as is. If you ever tow or put anything in the bed, it will still look great.
I like a little rake. When it is perfectly level, the front "looks" higher than the rear.... and if you add anything in the bed it gets even worse.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
