5th wheel with 1/2 ton
Toss in all your gear and supplies for a trip, water, 4 people, etc., then put it on a steep winding hill. Not uphill. Downhill. If you aren't done with a 1/2 ton and at the dealer buying a 1 ton, you are a brave man.
  • Replies 84
I certainly don't disagre that pin weight is likely to be the issue, but 1/2 ton tow ratings assume there will be two front seat passengers, but no allowance for cargo. 3/4 assume driver only.
From the 2015 OM:
Trailer weight rating (TWR) for 1500
series trucks is calculated assuming
the tow vehicle has the driver, a
front seat passenger, and all
required trailering equipment.
Weight of additional optional
equipment, passengers, and
cargo in the tow vehicle must be
subtracted from the trailer weight
rating.
2500 and 3500 series trucks is
calculated assuming the tow vehicle
has only the driver but all required
trailering equipment. Weight of
additional optional equipment,
passengers, and cargo in the tow
vehicle must be subtracted from the
trailer weight rating.
You sure I m pretty sure half tons accounted one driver at 200lbs.
Why dance on the line of towing capacity?? It's just not worth it. Before my family and I buy our next truck we also take into account the possibility of trailers being towed, new home purchases that may require we have a plow to plow our own road, things we may have to put in the back of the truck for the house. Sorry PPP=PPP ( piss poor planning = piss poor performance )
Came across this thread and its funny because I was coming up from Tennessee on I-81 in Virginia and saw a 1/2 ton Chevy truck pulling a 5th wheel camper and it was pulled over by the Police and a VDOT truck behind the Police car. The truck looked tiny compared to the camper.
Can you tell what body style truck?
no way i would pull a 5th wheel with a 1/2 ton...
hell sometimes my 26' jayco regular camper trailer scares me while pulling..
But that's just not using your brain. Pulling "a 5th wheel" that's the same weight as a bumper pull is SAFER in every measurable way. If you care about SAFETY, you should want to pull a 5th wheel instead of a bumper pull any time you possibly can.
Of course many 5th wheels are simply too heavy for 1/2 tons, but many are well within the ratings of the better equiped 1/2 tons. And in these cases, it's actually a much SAFER setup than a bumper pull of equal weight.
The knee-jerk generalized notion that pulling "a fith wheel" with "a half ton" is somehow less safe on its face than pulling a bumper pull trailer is simply FALSE.
I know mine is older, but just thought I would pipe in....The trailer weighs 4770 lbs dry, so about 6000 lb loaded. I am not sure of the pin weight, but it only drops the truck about an inch. The former owner told me they put heavier springs in it, has 5 leafs.
Truck is a K1500, has a 350 with the trailering package. I added a trans temp gauge and it rarely gets over 200F. I also use the Tekonsha P3 brake controller
It seems to tow fine, stops good....I know its back there and wouldnt want to go much heavier
Aw shit I tow my 32 ft 5 th wheel with 3 slides washer and dryer and with all my shit the truck and trailer weigh in at 18 980 pounds at the scale I think my truck has a 6000pou d curb weight. I only got a 5.3 with 6spf and 342 fears and it pulls the loaf really well 2300rpm on flat ground will keep its spread even up nasty hills can still keep it at 110km/h
And my truck is a 2013 chevy 1500 I'll post picks of my camper tomorrow it weights my truck down tills there's only half an inch left before the ass end bottoms out. But that 5.3 pulls and pulls hard and stops on a dime with the load. I seriously need 1 ton springs and air bags.
Wow....best of luck!
Geez you're pulling a 12k 5'er with a 3.42 geared truck non-nht . let us know when you blow your trans.
I'm not keeping the truck much longer so I don't care if I beat on it and its the same tranny behind the 6.2 witch is rated to tow 12 000lbs
    HWN808
    HWN808
  • Who's Online   5 Members, 1 Anonymous, 943 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
