my windows are open anytime it is nice outside, I would rather have the fresh outside air and feel the breeze. Mine was supposed to have the slider but it was deleted right before it was built at the plant. If I could get it for $1200 I might consider it and would use it anytime the windows are open and down as it really helps with in cab turbulence.
I went out of my way to ensure I got my truck with the power rear slider. I love it and use it almost daily when the weather is nice. I agree with others too saying it helps a lot getting rid of in-cab turbulence with the other windows open. I just open the back up a couple of inches and the air flow is great. Well worth it to me, but again, to each their own.....
I have only had my truck for a couple of months but a power slider was a must for me. When I had the 2003 Ram I sold before I bought the Denali, I routinely put long boards, trim, etc in through the rear window so the ends would fit in the bed. I love being able to do that without climbing in the back seat to open the window.
Love my rear slider and have it open every chance I get. Now just have to get used to remembering to close it which I seem to have a mental block about at times. In Seattle this can be problematic. A couple of weeks ago when I was on a business trip I get a phone call from my roomie saying "It's pouring here. Is your back window supposed to be open?" I was like "What do you think, sunshine?" D'oh! :)
I use mine all the time. With the windows down and the sunroof / slider open, it's pretty close to having a convertible truck. And the kids love it.
So with the Auto down feature on the remote, can we mod this to open as well? Im hoping it would be as easy as a rely like the fog lights. any thoughts?
I use mine quite often because of the turbulence with the regular windows. Now with that said, I would prefer the view of a solid window instead of the tiny slider. Wish the big 3 would copy Toyota and do the full roll down rear like the crew cab Tundra and 4Runner. That would be the best of both worlds. You get the perfect amount of ventilation with no turbulence and unnecessary to roll any other window down with the great rear view.
I wish there was an aftermarket kit that would drop the whole back window (like the Tundra has). That would be worth $1200 to me!
Not sure the little box in the middle is worth that kind of money.
It does look like a Titan back glass. Is that a custom job fitting a Titan window in the GM, or is this a kit that's actually on the market?
I use my slider when backing up a trailer at night since I got 5% tint on the back.
Or if I fart in truck its a great way to get the smell sucked into the back instead of the side windows past my face. :throwup:
If it isn't raining or freezing, my windows are down and the slider is open. I don't care how hot it is. Drives my wife crazy. I love my slider.
Not sure. Found the picture online and saved it.
I was quoted $700 for the slider from a dealer in Maine before I bought the all-terrain.
was this to remove the old window and install a new one? if so that seems like a hell of a deal. on the other hand, it's only a $250-$300 option on the sticker so if that's what your talking about, not such a good deal.
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
