Tires - height versus width
My 2000 Silverado came with 235 wide tires, my 2009 Sierra came with 245 wide tires and my 2015 came with 255 wide tires. For me, a 255 (or 265) wide tire is plenty wide enough for looks and traction. I am not excited about going wider and paying for the additional rolling resistance. I just realized that I can get my desired tire with an aspect ratio of 75 and width of 255. A stock 255/70r17 tire is 31.1 inches high. A similar tire with an aspect of 75% is 32.1 inches tall. This would give a similar profile as if I went to 285/65r17 but not as much rubber hitting the road. I am wondering if any forum members have made a similar change or if any of you can see a problem with going to a 75% aspect ratio.
A lot of k2 owners have gone from a 275/55r20 to a 275/60r20, so same width just taller sidewall. The one is 32.1" the other is 33", I lost an mpg or two but that is bc they were heavier. Then I tuned the truck and I'm doing better than stock.
My 275/55/20. Where almost 30 1/2" on the rim. The 275/60/20 on my rim are 32 1/4" the specs say they're 33" i wish they where right
Thanks. There is still a lot less sidewall height on the 275/60r20 than a 255/75r17. However, as I think you are suggesting, the difference for me from 70 -75% may not be that noticeable.
Less sidewall height, yes, but depending on the specs could be the same overall height. It's noticeable when I tow, I get less towing mpg with the 33's compared to the stock height tires
Cause of weight of tire is a lot more. And there not 33's lol
Actual height on vehicle vs. Measured spec height are always going to be different. They swell to around 33 going down the road.
And I also wasn't tuned for the taller tire, so it threw the numbers off a bit
We know that very similar wheel heights can be achieved whether you have a 17, 18 or 20 inch rim. The smaller the rim, the higher the sidewall of tire is needed. The smaller the sidewall, the firmer the ride and conversely the higher the sidewall the "softer" the ride. I like a comfortable ride but I don't like sluggish handling characteristics. I wonder if high sidewalls on a comparatively narrow tire will feel less responsive when cornering and maneuvering through traffic. I know it is a truck and not a sports car but I don't want to make things more awkward!
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
