Turn Signal not working
Sugarray_11
I got an 09 Sierra SLT and just realized my front drivers side turn signal don't work. I replaced all the bulbs and everything is working but those 2 amber turn signal lights dont work. The parking light on the same bulb works. The same side in the back work. It's just the 2 that don't blink. What do you all think? New to the forum. Thanks!
Check the underhood fuse box first (I forget if they're there, or in the cab - easy enough to check both anyway).
Could've blown when the old bulb failed.
I checked both out and they look fine. Thing is the parking lights still work and in the same.side the blinkers flash except for the 2 amber ones in the front.
Parking lamps are a totally different circuit. Completely unrelated to the t/s, except that they share the same bulb.
I'd grab a test light and see what has power, and what doesn't. I can assume the ground is good since the parking lights work. Do a visual inspection of the wiring first - the problem could be an obvious one.
Also make sure that bulb is in correctly - there are 2 different height pins on the side - they can only go one way in order for everything to work normally.
EDIT ... since you have an '09, they're probably flat, so scratch that.
  • 3 years later...
I have a 2007 Sierra 1500 no signal lights an no dash lights , lights on radio an odometer lights work they  will dim up and down
