1 hour ago, GTPprix said:
Not weird, normal ;) If you want the Chevrolet startup logo etc (e.g. you have a Silverado) it will have the SUV icon as its all tied together.
Honestly, I might not of even noticed had Chris not told me ahead of time.
@GTPprix
Chris, you think this will be the fix for the cluster we did for my 2015? Don't know what year it came from but it's the same problem.
[mention=130449]GTPprix[/mention]
Given the cluster you used yes this likely would, please contact from the website and we can set that up.
That would be great. I can send it in whenever you want, although I should probably wait until you see if there is a way to suppress that steering notification in getting.
May have a lead on that as well actually but please email so we can discuss ; thanks!
Will do. About to head out with the family for a few hours. I'll email you either later today or Monday night your and you're regular hours. Thanks Chris
Im just curious, I missed what the actual fix was. And I cant find it. Is it in the program, or settings, or a jumper?
On 4/18/2019 at 3:07 PM, GTPprix said:
So the small number of you experiencing this issue owe @Jchoi a big thank you :) We were able to confirm the work around to the GM bug does indeed work on the 2018 units (and likely the 2019 units) to my knowledge only one person with a late 2017 has this bug but I'm hoping it should work as well. Contact us from the site to schedule a patch application :)
@RACERX7775, it's programming.
On 4/13/2019 at 3:19 PM, GTPprix said:
Was hoping to make an official post after there was a confirmed fix however very long story short there is a bug that seems to have been introduced into the late 2017 Firmware that carried into the branch used for the 2018-2019 units as well. Basically The clusters ignore ANY configuration for a rear park assist only even though they are configured as such; the bug even allows for the display of the park assist on/off state messages but not the actual sensor data.
This would never have been an issue for GM as they never built any trucks that used these clusters in that time frame that DIDN'T have UD5 (Front and Rear Park Assist). I have spent a metric ton of time recently benching up a mockup to test this and indeed was able to see no matter what data frames were sent (or emulated) from a park assist unit the clusters would not display anything for rear park assist. Jchoi is testing a third revision of a work around that hopefully should work as we were able to display park assist information on his unit on the bench, I was even able to replicate this situation in my own 2018 Denali.
Hopefully will have something to report here very soon, it should be noted since the discovery of this we have stopped taking any orders for 2018 trucks that have rear park assist only but again hope to reverse that the second we have good feedback.
@RACERX7775
I am really wanting to to this switch to a denali IP but have been looking for a 2014 cluster with no luck.  Am I correct that the Denali cluster must come from same model year as my Slt.  Also was wondering does the Denali cluster from 2014 come with the off road page?
Do you mean.... whether it's in 2  or 4wd?
there is an off road page on later model trucks showing wheel angles and vehicle angles plus it shows if it is in 2wd or 4wd
Payton, you'll need to source a 2016 red cluster (your gmc cluster is red, right?) along with the HMI/Radio modules.  Pretty sure you have to do this at the same time as the cluster, as these things all need to talk together to work, but you'll get android auto and carplay too.  If you havent contacted WAMS for part numbers and checked the other thread on upgrading, please do so.
I did the full upgrade, and I have the off-road page on my cluster.  Its fully functional.  Since you have a GMC, you might be able to get the cluster to show the off road page as a truck.  On mine, since there was no silverado denali cluster, I get to look at a tahoe/suburban on the off road pages and door open icons, etc where it previously showed a truck.  You'll probably have to enable the off road page in settings as I dont think it comes enabled from the get-go.
Just got my cluster back from Chris after having his patch done to correct the back-up sensor graphic "disappearance" issue.  It works great now!  Thanks Chris and thanks @Jchoi for being the guinea pig.
Thank you for your patience! :)
FYI for anyone just tuning in the fix has been built into all of the clusters that had this issue now so its all good in da hood :)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
