Weight in the rear for winter
Most the time I drive in the snow I have my quad with a plow on it so that's enough for me. Other than that I've not had issues with not putting weight back there
  • Replies 75
When I had my 1500 I didn't add any weight. But I did get it stuck one time too, snow was just a little too high and basically high sided it.
In my 2500 I add some weight after towing season to soften the ride. Has nothing to do with the snow.
The truck weighs 5500 lbs right? That's like 1350 on each corner. Or about 1300lbs per square foot of foot pad from the tire
Tires have a LOT to do with it. My old ecsb 2wd was a beast. Hardly ever got stock. Never added weight once. My s10 2wd was horrible. Had to add weight.
Thanks for the input. This being my first real winter in the truck I'll just see what happens. I do have the stock SRA's so I'll see how they do but like was said put it in auto on flurry stuff and 4x4 on thick overnight stuff. Thanks a bunch guys
Sent from my Nexus 6P using Tapatalk
I still have the SR-As and haven't had a problem with them in the snow. But, we don't get blizzards or anything that in northern NC. We sometimes get a decent storm, but usually nothing more than 6"-8" and sometimes all we get are dustings and flurries. 4x4 really does help a lot to where you can have cheap tires and doesn't really effect it much. Of course there are plenty of tires that are a lot better in the snow than the SR-As. I'm just saying that they're not useless like some people make them out to be. It's not like they're slicks like some people are acting like they are. Another way to help is to air down the tires a little so you have a bigger contact patch. I wouldn't go as low as 15 psi, but maybe somewhere around the 25-30 psi range.
Friend at work has Sr-as said he don't have a problem in Wisconsin winters but in 2 wheel drive he has tire spins when it's wet on take off.
Haha!
You guys need to come and try Canadian winter to see if that changes. SRA's does not make the cut where I live.
Where does the OP live? what kind of snow is he talking about? Last winter was my first year with the new truck and plow. I only had two 70# sand bags in the far rear of the bed. Factory tires. I was able to plow through 3' drifts of heavy snow from one December storm.
If you are staying on the pavement, you really don't need any weight. Just use 4WD if roads are not plowed. I only engage 4WD while I'm plowing, otherwise I can pretty much drive around all winter in 2WD. I haven't gotten into using that 4wd auto function yet, I guess I like to know if its on or not.
I always think, if you can't operate your vehicle normally on the road, stay in bed til the plow goes by.
That was kind of my motivation to go with the largest diameter tire I could get without going much wider than stock. More ground clearance without rubbing
4WD - 2 #40 bags of sand and 2 #40 lb bags of salt stored behind wheel wells, not so much for weight but traction if you or someone else is stuck on compacted snow or ice.
narrow tires are better for snow driving (or plowing) I drove a plow truck part time for 15 years.
Wide tires aren't the most efficient or best in the snow - there is no argument here this is science
Live in central mass. We usually get pretty good snow . The year before we had storms every other day. By the time the season ended we had 50 inches of snow.
I did several trips up into the mountains above us last winter. I tossed two big bags of sand in the bed. Had a tow strap and chains. Never needed any of it. But this was my first time driving in the snow with my truck. We took the grandkids up to play in the snow after a major storm. Never broke traction during any of the trips. Love my truck. Almost had to help a Toyota during that trip, but he managed to get it back on the road. Left the bags of sand in the bed until spring.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
