Used a small strap I found and looped it through the child seat loop to keep my bag from falling in the foot if I have to hit the breaks too hard.
Sent from my Pixel XL using Tapatalk
  • Like 4
Freaking brilliant! My damn computer backpack falls all the damn time. I'm gonna have to steal this idea.
Yep - Stealing this idea too :)
I just put my laptop backpack on the floor in the back.
Sometimes I keep a tool bag in the floor.
+1
Where did u connect the power to? I also have a light bar that seems to receiving stray voltage. I connected to one of the studs under the black cover that is above the battery. I replaced my relay and thought that did the trick. But the same thing is happening. Any help would be appreciated!!
So I was finally able to get under the hood and tinker yesterday. I connected the light bar under the black cover and it seems to be working great! I just had to buy a nut to screw them down but it works fine. Could it be a faulty switch? That would be the only place I could see something happening if the relay was replaced.
Added an Aftermarket Mirror Fold Module so my DL3 Mirrors fold/unfold like the LTZ do with the Key FOB.
Cost was about $50. But can be done for about $35.
2016 Silverado LT - Fold Your DL3 Mirrors with your FOB like an LTZ
https://r.tapatalk.com/shareLink?url=http://www.gm-trucks.com/forums/index.php?/topic/196138-2016-Silverado-LT---Fold-Your-DL3-Mirrors-with-your-FOB-like-an-LTZ%26%233&share_tid=196138&share_fid=33003&share_type=t
Edited by pgamboa
Thanks for the info. After two faulty relays I desperately tried another "heavy duty" one from the local parts store. It is currently functioning correctly.
Ordered this change holder that fits in the cup holder. So far only negative about my truck but not a biggie, there was no place to put spare change.
Edited by quise2024
That's cool, where did you find that one? I put my change in the cubby hole by the light switch but when there's too much, it rattles too much for my liking.
eBay .. same one os all over amazon and ebay so i kept clicking til i found the cheapest one lol. Funny thing is when i got itn came in an amazon box with the prime tape all over it, arrived in 2 days too.
Heres the link: http://www.ebay.com/itm/121985705222
Sent from my SAMSUNG-SM-N910A using Tapatalk
Lol... that's usually what I do. Gotta save where and when you can. Thanks for the link
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
