My local dealer is $60 for oil change and rotate. If I buy filter and oil its about $55. I'll gladly spend $5 extra to not have the hassle. And I get to drink coffee, watch TV, and know that if anything happens it is all documented.
Last timeni checked it was about 5 bucks more to go to the dealer, not worth the aggrivation to do it home cor that
No fun in that. Rather do it in the drive way garage door open watching NASCAR or hunting channel and drinking a beer, plus it is cheaper then going to the dealer or at least in my area. Doing my self $56, $48 for oil and filter $8 for the six pack.
Sent from my SM-G935V using Tapatalk
Sorry guys. I guess I was having a blond step-daughter moment. Ha ha. $5 bucks to have someone else do it is worth it. Agreed. I usually do my own maintenance but winter maintenance I’m happy to pass on to someone else.
If my dealer only charged $5 more than doing it myself I would take it to my dealer. My dealer charges $80 for the oil change.
Sent from my SAMSUNG-SM-N920A using Tapatalk
I guess I'm just old enough to have a bunch of free time to do it myself and take pride in the job done right the first time.  Heard too many tales about 6 qts. of oil put in an 8 qt. engine or filters replaced way too tight or drain plugs rounded off or stripped out.  Oh, well; come join me in the morning and I'll let you watch the old man work.
Or maybe not.
Fumoto valves, for sure!
On 2018-01-29 at 2:27 PM, Grjfer said:
Having spent 10 years in the Navy I have no issues with brass & salt. Many over the road trucks running them with no issues either.
May be a lot more to do with our above and below freezing temps that promotes oxidation. Sometimes brass will turn from the humidity and salt in air - with no actual flow across it of any kind.
Im on an island in the Atlantic Ocean and we use salt/sand on our roads lol.
One of the major quick change oil lube places advertises you can stay in your car while they change your oil, so you can make sure they do it right.
at the dealer several years ago, I was watching from the waiting area. After they were done I asked the fine gentleman how he was able to lube the pitman and idler arm without loosening/lowering the skid plate. He told me that he would do it again.
Im all in on the 6 pack, it also doesnt help thatbthe dealer is 5 mins from work bye foot, just 2 convienent, and like mentioned the tire rotation, ill changethe oil on my firehawk, or boat with the time saved ;o)
On 1/30/2018 at 7:09 AM, CharlestonJoe said:
 What’s everyone doing about the oil filter change? On the V6 its above the plastic shield and I catch heck trying to remove the filter without making a mess. Filter relocation?
I use a piece of aluminum foil and wrap it over the frame of my wife's car. The oil filter is directly above the frame. This allows the oil to run down the foil and into the pan.
Don't ever pay full price for an oil change at the dealer.  There are usually discount coupons here (Certified GM Service website):
http://www.mycertifiedservice.com/
Did something similar to this with my dad's '86 Celebrity, oil filter sat over the frame that would hold 1/4 of the oil, no drain hole on it.
This was the best money I ever spent:
http://formafunnel.com/
You can get them on Amazon and other places for around $13,  I use it for all kinds of garage activities!
Those are popular with commercial lawn mowers. Nice little accessory.
you can also make those out of a milk jug.  just slice the bottom at an angle
CLASSIC!!!
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,978 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
