Installed a new grille in my truck. Took the chrome honey comb with black bow tie out and installed this $50 craigslist take off grill along with my black bow tie. Opinions?
  • Like 4
I like that A LOT
In attempt to revive this thread....
just ordered b-pillar covers, uv coated acrylic. $33 cad shipped.
https://www.ebay.ca/itm/Glossy-Black-B-Pillar-Post-UV-Coating-Cover-Trim-4Pcs-For-CHEVY-14-16-Silverado/172298433482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
going for this look. Photo taken from 1sik_z Instagram
  • Like 5
I do like blacking out the B pillars on colored trucks. I think it looks better, more clean. Looking forward to seeing it man.
Looks good. I’m going to give it a shot, 22” wheels? I have the same truck in a 2500.
Not my truck, pic was taken from "1sik_z" in instagram account. I'd assume 20s though
The front plate is what does it for me. Two thumbs up. The grill looks good also.
Theyre 22’s per his instagram
Edited by Arkangel
Got this done last night. This is the Deezee #43102 tailgate assist. I bought it from Amazon for 25$. Definitely recommend it. It was simple to install too. 15 minutes
That's one of the handiest features I have added and for another 25 bucks or so you can put it to really good use with a remote dropping tailgate.
I like that. That’ll definitely be added to my list for the spring time
Do you have more info on the auto dropping tailgate. Maybe pm with what is needed. Also if it works with the auto lock kit.
It will work with the auto lock kit (the PAC TR7 has numerous programming options) and I'll post a link to my install thread in a minute.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
