Hey all,
I recently purchased a couple shallow mount subs, a subthump box, and an amp/wiring kit for my 2015 GMC Sierra SLE. I also purchased this line output converter to get the signal to the amp from the stock wiring. I searched for "line output converter" and literally nothing came up on the forum, so i'm curious if anyone knows the easiest place to tap into to get the subwoofer signal to the amp? I'd greatly appreciate any help!
My truck is a 2015 GMC Sierra SLE, does NOT have the Bose factory system.
PAC LP7-2: http://www.pac-audio.com/productDetails.aspx?ProductId=1188
Gear i'm adding:
2x Rockford Fosgate P3SD2-12
1x Power Acoustik EG1-2500D -- wired to 2 ohms, about 800w RMS total
subthump dual 12" box w/ amp rack space
Thanks!
Captain
Edited by CaptainMcFunk
Anyone have any ideas on this? I scanned a thread yesterday for a long time and came up with one person that stated these were the wires to tap into, but no one said anything else -- Anyone have a picture of the harness i'm looking for to tap into?
For non-Bose, you can tap the rear speaker wires in the B Pillar before they go thru the harness to the rear doors. They are twisted pairs.
Left Rear Speaker (+) green // (-) green/black
Right Rear Speaker (+) white // (-) blue/black
  • Thanks 1
If you have the bose upgrade you tap into the amp behind the rear seat.
I appreciate the response, but I included it in the original request that I dont have the Bose system, as that seems to make a huge difference in where you tap in. As i've been going along today preparing for this install, here is other info i've gathered:
ITEM WIRE COLOR LOCATION
Left Front Speaker (+/-) // blue - brown/blue // radio, green 16 pin plug, pins 1 - 9
Right Front Speaker (+/-) // yellow - yellow/black // radio, green 16 pin plug, pins 2 - 10
Left Rear Speaker (+/-) // green - green/black // radio, green 16 pin plug, pins 3 - 11
Right Rear Speaker (+/-) // white - blue/black // radio, green 16 pin plug, pins 4 - 12
I was hoping to just tap in at one of the plugs in or near the BCM, which may be possible, I just don't know. A tip that I got is to pull the B-Pillar panel (between front & rear doors), pull back or cut the tape on the wires going into the rear door to look for the speaker wires. It should be the ONLY TWISTED PAIR in the bundle. I may go this route since I don't know if there is an amp after the green 16 pin plug at the radio.
Forgot to mention which power source I used for the amp's remote on....
If you look under the driver's side dash between the brake pedal and parking brake, you'll see the fuse/relay box (it's about 6" x 10" and has a smooth black plastic cover, just like on the GMT-900's). Pry the clasps on each side to remove. On my SLT there are three main banks, left to right, with the first being unoccupied (see attached pic). The slots within first bank are labeled 1-20, though only 11 actually have male connectors. I used my tester to determine the following: #'s 7 & 17 are constant 12v power [always on], #'s 10 & 11 are grounds, and #8 is the RAP [retained accessory power] ignition signal wire (again, see attached pic)
For newbies, RAP powers on with the key rotated to the first position and remains on until the ignition is turned completely off AND the driver's door is opened, just like the factory radio.
Have you tried searching LOC? There is a youtube video of a guy who put it behind the radio inside the dash. You should use the font speakers since since the rears are quieter, the only down side is the front left speaker is the one that makes your blinker sound and door ding. I've yet to install an amp/subs but thats the information I found so far.
Edited by Donolie
  • 1 month later...
If you'd like to clean up and have full amperage for other mods I built oem supplier (Delphi) harnesses to tap that x7 port.
$45 plus shipping. GM parts are $68 and not pinned
To be clear, I but from who gm buys. I meant if you purchase through gm, that would be the price and the trim would be blue. It's still a Delphi connector
  • 2 years later...
  • 3 months later...
So I'm doing this as well and I find the twisted green and green black wires on the drivers side but no white blue/black wires . Would they be on the passenger side ?
Sent from my SM-G975U using Tapatalk
  • 2 months later...
I just did the LLJ harness and it was easy install, took a couple of weeks to get the harness as they were behind, but communicated well. I plan on getting another adapter for the other truck.
  • 1 year later...
  • 5 months later...
Do you know if it's the same on 2017 Silverado LS double cab No Bose speakers??
  • 2 years later...
Why can't you tap into the speaker wires in the B pillar with the bose. I have a line converter that says it can handle a amplified signal up to 400 watts.
Idk but I've been wondering the same thing about my 2013 ltz with Bose and after many unsuccessful searches I think I'm just gonna try it and see. I've got the Kenwood amp and subs tapped into the factory sub wires at the amp and it sounds alright and gets loud but leaves something to be desired I guess. I had these same subs and amp installed in an old Dakota with a basic alpine half din CD player with an old iPod cord plugged in the back and it sounded amazing.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
