Leveling with Coilovers & Upper Control Arms
sethwick75
I like the look of the Mazzulla, the Baja Kits and the Camburg the best. I only have heard reviews of the Baja kits long arm travel and the camburg arms though. I do not thing you can wrong with any of them. Now that we have seen a member with Fox and Kings have contact issues with the Cognitos I am leaning to those 3 UCA's.
Yes but the basic Mazzulla kit does not include the rear shocks which are an extra $783.00
so the Mazzulla kit with King coil overs $1,799 + rear king shocks $783. + control arms $1,000 = $3,580.00
If you do not need 2.5 shocks with reservoirs you can get a complete 2.0 kit from icon for $2,813
I still think the King set up would be better but that depends on how thick your wallet is :D
The icon coilovers are 2.5 the rears are 2.0, I got the stage one kit without uca's for $1445.00 from auto anything with a 20% off deal. I went with cognito uca's put me right at $2000.00 for everything.
Thank you for clarifying fairway605! Great find using the autoanything 20% off. I used that deal a few months ago for other goodies. What height did you set the front coilovers at?
Great clarification - I tried to use a 22% off code last week and it didn't work on any of the lift kits (King, Icon etc). I've got my fingers crossed for Black Friday.
I am searching for black Friday deals too. I will post if any pop up! :fingersx:
For a truck that's driven on asphalt, you would actually see more of a performance advantage out of the box on the Icon shocks hands down. Not saying anything bad about King, they build an amazing product. If you were building a dedicated off-road truck, I would go Kings hands down.
But the digressive valving in the Icon's is going to shine day in day out on any street driven truck.
Regardless, if you stick with a quality product you won't be disappointed !
  • 3 weeks later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
