new body and nnbs/ denali wheels
rully1012
whats up guys I have stuff off of my old nnbs ext cab and my current 2014 Denali Sierra
Everything is located in Los Angeles area and will ship everything. I will try to split shipping with buyer.
i will also be posting things up for sale on another forum and locally so i will update thread as sales happen
first is a set of 2014 Denali 20'' take offs
they are very clean overall a few scuffs but no pitting or stains on the chrome
im asking for 800$
tires were marked on the CPO paper work in late November as 7/32 rears and 8/32 fronts
removed from truck in December
also selling 2 sets factory Sierra/Silverado round foglights.
one set has small road marks but not cracked all mounting tabs in place
second set was removed at 1000 miles off of my brothers silverado 2500 basically new
Crew cab Denali chrome removed I have the following parts availbale.
4 door handles 75$
4 window trims 140$
Factory chrome steps 250$
The following parts were removed from my NNBS Ext. cab
1 stock radio 6cd 40$
2 black texture door handles 35$
2 gray stone metallic painted handles 35$
1 Subthump under seat 10" sub box 65$
1 pair of gray stone metallic power side view mirrors 100$
Can you post pictures of the running boards?
Best pics I have till I'm off work
Sent from my Nexus 6P using Tapatalk
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
