I hope I am not breaking the rules
Sean3565
I hope I am not breaking the rules by posting pics of my Sierra's new baby brother. Some of you may laugh, but all I can say is don't knock it till you try it! This is a fun little car and it will help keep the miles off of my truck.
Driving one of those will get your man card revoked for 10 years. Those cars were made for girls. You do realize that Fiat is at the bottom of the barrow when it comes to reliability? Sadly Chevrolet is not too far from the bottom themselves. But it's been coming.
https://www.cars.com/articles/consumer-reports-reliability-study-toyota-thrives-fiat-fails-1420682551916/
I still keep a 1987 subaru wagon. I can juggle 3 cylinder heads, and carry a complete engine myself.
I gave the little car stuff a try too.. I park it as antique. No longer a real car.
the steel. I cannot get over the steel standards they choose.
The mileage is insane, small engines. Not worth it. The energy bounced off to consume all the fuel is called pain.
If you keep your little fiat running for realistic longevity, the parts will be breaking like a toy elsewhere. Suspension, brakes, little tires..
Never doing a little car again.
Anyone else grow up with calling a 305 chevy "the little one"?
I bought a little economy car too!
Lol
What's sad is my camaro is the best gas mileage vehicle in our garage
I got you all beat with putt-putt. A 2007 Cobalt LS. Good on fuel and get this, it turned out to be the best GM I ever bought. Only failure in 8 years was a fuel pressure sensor.
A weight challenged chick at work bought one of the little fiats. Barely fits.....
I've never understood wanting to 'keep miles off my truck' odds are you'll wear it out on age before mileage, if I am paying as much as I am for my truck I wanna drive it everyday.
My Cruze diesel is my daily driver. Averaging 47.8mpg is a nice benefit. What sucks is long trips, going 700 miles to a tank, hard to not stop but mother nature has other plans. :)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,321 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
