9 hours ago, lerbud said:
You probably pinched the wiring in the harness and shorted it. That is what happened to mine. I was able to fix the harness and route in better after the repair.
I’ll take a look thanks
So at this point, does someone have a definitive list of OEM part numbers to be able to ADD this to the SLE 2016 Yukon XL that didn't come factory installed?
I know it needs a new harness since there is no 12V plug back there to plug in the wireless module (I opened and verified this).
I guess I'm looking for the module number, harness number, OEM trim pieces for the MAT, and whatever else is needed.
Can anyone help me with that?
Thank you.
Chris
Thank you.
Chris
The module is compatible for any vehicles that have wireless charging. Module part # is 13521066. If your console already has wireless charging, you’ll just need the module and adapter harness. If you need those two items, I stock them.
If you are trying to retrofit this into a console that doesn’t have wireless charging, that may be a different path. You’ll need a lid that supports it.
I make a harness that T’s off the rear 12V plug for $45. Plugs inline to the 12V plug harnesses.
Lastly, not all charging mats fit the lids.
I assumed my lid could just be remove the non ribbed mat and put in a ribbed mat and the charging module and harness. Is that not the case? It seems so from all the videos I see of people opening it up....the mounting pems are there, just no module.
I am looking for the OEM harness so that when charging is working the lightning bolt shows up on the screen, that needs the harness trigger wire in the OEM harness for that to happen.
I can do all the work, just need to know what PN of that harness should be to do it. I can't get a clear answer on the PN of an SLE trim that has wireless charging to buy that part. Many don't show the proper image of it either....so I'm hoping someone who's BTDT might know.
The 12v is the easy route, but I'm looking for a true OEM retro install....if I had taken the time to research SLE vs SLT vs Denali, I would have ensured to get a truck with it in.....unfortunately, it was an impulse buy and not enough research done to make a proper decision, so ultimately my fault.
As an FYI, in my 93 vette, I installed OEM FX3 ride control and LTPWS, so I understand what it takes to make this change and ensure proper wiring is in place to cover all the bases.
TY for the fast response.
Chris
Chris
The lightning bolt icon that shows up will only work if you had it before. I added all the wiring in my truck include that indicator icon and it didn’t work. Likely because the BCM is not “enabled” to show that icon.
I don't mean to hijack this thread swapping console lids and wiring, but just got my 18 LTZ and it already comes with the wireless pad.  Does it only work with certain phones or is there a certain setup needed to get it to work?  I have an LG android and it didn't seem to do anything when placing it on the mat.
Thanks
If your using an iPhone, it works on the 8 and up.  I believe it's the same on most the android phones as my Samsung Galaxy 8 has it and not the previous version.
The iPhone 8, 8 Plus and X all support wireless charging, but you can add it to any older model with a Lightning port. Here's how to add wireless charging to the iPhone 7 and older phones. If you buy an iPhone 8, iPhone 8 Plus or iPhone X, you'll find it supports Qi wireless charging out of the box.
https://www.techradar.com/how-to/how-to-wirelessly-charge-your-iphone-7
Android Phones:
  • Samsung Galaxy S9 and Galaxy S9+
  • Samsung Galaxy Note 8.
  • Samsung Galaxy S8 and Galaxy S8+
  • Samsung Galaxy S7, Galaxy S7 Edge, Galaxy S7 Active.
  • LG G7 Thinq.
  • LG V30.
  • Sony Xperia XZ2.
  • Nokia 8 Sirocco.
Salesman pointed out I have wireless charging although I did not have a phone that supported it. Now that I have a phone that supports wireless charging I have tried and found that I am not getting a charge, and the pad is not big enough for a iPhone XR. I opened up the consol lid and removed the inner cover to find there is no module or wiring, just the pad built into the consol. Next time I buy a car, I will open the hood to make sure the engine is included with the body....
So the work around is a 12v usb plug in pad that sits on top and covers the OEM pad.
Works great with a case on the phone and looks good. $25 on Amazon.
Wireless Car Charging Pad, ZealSound Qi Car Charger Mat & Phone Holder with Fast USB 3.0 Car Charger Adapter Phone Holder 10W/7.5W/5W Fast Charging Compatible for All Qi Enabled Phones (Black)
by ZealSound
I just purchased a 2017 Sierra and the wireless charging doesn't seem to kick in on my Pixel 3.  I have tried moving it around slowly on the pad with no luck.  Also tested with and without the case.
When I look at the compatibility list on the website I see Pixel 3 is not listed.  Is this true?  Will the updated charging kit fix this?
https://my.chevrolet.com/content/dam/gmownercenter/gmna/static/pageImages/learnAbout/articles/documents/GM_Wireless_Charging_Compatible_Device.pdf
Edited by smileyman57
added case statement
My Pixel 3 in an OtterBox charges just fine in my 2017.
That is interesting. I test drove 2 2017s and a 2016 and non of them would charge it. I wonder if it some setting on my phone or something.
Sent from my Pixel 3 using Tapatalk
What does this kit provide for you over what is in the truck already? Or is this kit only for those that don't have wireless charging in their truck?
I have a 2017 Sierra, would this fix my pixel3 charging issue?
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
