FYI, those hooks are too small as well...my RV came with those, and I had to swap out with regular chain hooks because they wouldn't fit the receiver holes.
I think those s-hook are meant to pass through the holes in the receiver and then hook back onto the chain, but mine didn't have enough chain to do that either.
I don't think they are meant to pass through, mine won't. I have to hook the big end of the S through the hole in the hitch.
On the 2.5" receiver, mine would pass but not enough to loop back and leave slack for turning.
I did what the others stated, changed the hooks out for ones that fit right...
Can you provide a link to the hooks you ended up getting? Based on what you have said about other suggestions, your hooks must meet all your criteria so I'd be interested in checking out the same ones you got.
Thanks.
Thanks.
I replaced the factory s-hook with a grade 70 chain hook with safety catch that fit my receiver.
This is my utility trailer, not my camper; but it will give you the idea...and the 2.5" receiver on my truck, which those hooks fit perfectly.
I've installed chain hooks on every trailer I own because they are easier to use and work better.16d39cecc36758b6ba48c6a6205eae48.jpgad38b4483d51ada525f700cc1111bd8b.jpg
Thanks for the pics and hook info. I can see why your setup works easily. The holes in your hitch are way bigger than on mine. That's been the trick. Finding something small enough, yet strong enough, to fit.
Here is a 13. Up and out. Not sure if new hitch is any different.
Yup, very different. The "up" holes (in your pic) in the 16 are about the diameter of a pencil. The holes on either side of the receiver are also smaller.
Believe me, if it had been as simple as your pic makes it look, I wouldn't be asking for ideas.
I used two 5/8" quick links from Tulsa Chain, rated for 8,100 pounds each. I then attached an eye bolt through the bottom of the hitch to hook up the safety brake cable (this idea was from forum member jhplak325).
Yeah, it looks like I'll be going with the 5/8" links too. The eyebolt is an interesting idea for the brake cable. Does the safety cable just slide through the slight open end of the eyebolt?
Edited by Mike Hamm
My safety brake cable has a snap link on it, so I just attach it to the eyebolt.
Ideally I think the safety cable should be attached to frame somewhere, by I couldn't locate a good spot.
This. You actually shouldn't attach your breakaway cable to the same spot as your safety chains. I have seen receiver hitches come off the truck frame completely. When that happens if your breakaway cable is attached to the hitch then the cable will never pull and your emergency brakes will not activate. The trailer will actually just float away with the hitch and receiver still attached to the ball.
Right. But until GM actually thinks through that these trucks do some towing, there aren't too many options.
Now that being said, these hitches are part of the frame and the chances of them falling off are rather slim. And even if they did, the safety brake cable only needs a little tension to be set off. And the slightest dragging on the road might just be enough in most cases.
Edited by SouthpawHD
Not to mention if the receiver separates from tow vehicle, you probably have worse things to worry about at that point in time...
I've only heard of it twice, once was a uhaul-installed hitch with brass bolts (to prevent corrosion of course), and the other was a 2nd gen Dodge that had a metal fatigue failure from being overloaded all its life (rip parts of the frame off too). In all my years following the diesel forums, those are the only two hitch-related failures I can remember.
I worry more about someone tampering with my setup...stopped at a rest area, some teenage kids were hanging behind a SUV when I pulled in. I ALWAYS do a walk around before I start back down the road...the jerks had pulled the spring clip from the hitch pin so that it would fall out later down the road.
Got my new quick links installed. I think I'm going to like this better than the other setup.
Trailer is at the dealer for some warranty work so I'll be giving these a try when going to pick it up.
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
