My compressor blew a few days ago right around 57k. Got it fixed and the A/C was blowing ice cold, and was loving every second of it. About 3 days later (yesterday) my condenser failed. Now I'm back at the dealer, without a warranty I might add, getting that fixed too. GM needs to get it together. I really hope the new 2019's don't have these issues. For what it's worth I have a 2014, but I've seen these issues all the way up to the 17's.
Edited by EChavez
After reading this thread, it sounds like a condenser leak is a foregone conclusion. I have other mechanics and owners telling me it is a known detect (bad weld) and its just a matter of time. GM won't replace it until it breaks, and if it is under warranty, they will replace it with a part that has a similar defect.
No wonder the tax payers had to bail them out. GM is a horrible company.
I refuse to drive a vehicle without working AC. Pile it on to all the other little issues I'm having with this truck, and it really is a purchase I regret.
If (or should I say "when") my condenser fails, I'm going to have it changed out at the Ford dealership. I'll have them change out the rest of the truck with it.
Well.. bought my truck in October. Turned on the AC for the first time today and it was nice and hot... Kids were sweating up a storm on the drive home.. 2014 LTZ crew w/short box with 74k. Too late to call a dealership tonight but I'll see what's up tomorrow.
Thank you for the information all. Hopefully I can see what is up and if I find the crack it can be taken care of easily and cheaply too. I just dropped a lot of money into an audio system and really don't want to rip it all back out...
my ac went out on my 2014 GMC two days ago . checked the condenser with soapy water and sure enough condenser leaking at driver side. called dealer was told Gm had extended the warranty on condenser for 60,000, took it in and it would be free of charge, great i said , get a call from dealer saying my vin was not covered. two days later got fixed it dealer helped me out big time . $250. out the door.
3 minutes ago, silverado990 said:
yes ,60,000 miles mine has 56,000
So there an extended warranty but your VIN was one of the ones covered? How the **** do they decide certain trucks are covered and some arnt when it’s the same condenser and compressor on every truck.
What am I missing here? Why was yours not covered when you are under the mileage they specified?
Me too! Same details as above with the ac condenser defective weld. So reported to my dealer, GMC customer service online and safercar.gov. Seems this in fact needs to be included with special coverage 17336-02 along with the Escalades, Tahoe and Yukon victims. The Sierra and Silverado customers need to report on the safercar.gov site. I was out of coverage in the bumper to bumper with 47k miles. I would challenge as this should be considered as Powertrain. What do you think?
dealer had investigated my truck called me back and took care of most of the cost. I still have pending charges I am trying to be considered to be credited back to me. Charge was labor only.
Edited by 2WsierraSLT
I think the 2014's are not covered under the extended warranty.
I wonder if you could slap some JB weld on the condenser to sure it up and prevent this problem?
Add me to the list. 97k miles and A/C started struggling to blow cold air. I checked condenser and sure enough, leaking from the same spot as everyone else.
I'm not even going to attempt to ask dealer with 97k miles. I'll be changing it out myself this weekend.
Been 8 days since I dropped it off at the dealer. Part still hasn’t showed up. They’re assuring me it’ll show up today, but honestly I’m tired of hearing that. If it doesn’t show up today I’m picking my truck up. This is ridiculous.
Fellows reported to your dealer, GMC customer service online and safercar.gov. Seems this in fact needs to be included with special coverage 17336-02 along with the Escalades, Tahoe and Yukon victims.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
