11 hours ago, Mpost26 said:
Has anyone had to add tranny fluid after the condenser change?
I added a little just because I knew I lost some. According to the dipstick I didn't need to add any?.
Yea I figured. I changed my condenser after a tranny drain/fill. Fast forward a few months my tranny has a hard shift from 2nd-3rd. It has been doing it for a couple weeks so I finally checked the fluid level and it’s low low. Like don’t drive low but I have no signs of a leak anywhere. I have an appointment at the dealership tomorrow and have a feeling that they going to say it my fault. I think they didn’t add enough fluid.
I’m confused, why would you loose tranny fluid when changing the condenser?  And about the dipstick; where the heck is it?  I can’t find it and am under the impression there isn’t one and the tranny is factory sealed.  Lastly, how did you add fluid and where?  Eager to learn...
The condenser is also a transmission cooler.  It has two flow circuits in the same component so you’re going to lose a small amount of ATF when you remove the condenser.
As to the dipstick, my understanding is that the 6 speed has a dipstick in the K2 trucks, but the 8 speed does not.  On the 8 speed, there is a stand pipe on the plug in the pan and you fill through that pipe, but only after the fluid is up to temp and with the engine running on a level surface.
Because the condenser works for the a/c system and is also a transmission cooler.
The transmission cooler lines are located on top of the condenser on both driver/passenger side. They are held in by clips.
If you take the condenser out carefully, you can transfer the existing condenser transmission fluid over to the new unit which is what I did.
Edited by Sierra Dan
Don’t they do that when they vacuum and recharge your AC system?
I replaced the condenser myself for around $200 all in.
Didn't want to pay a shop $700-$1200
Pulling a vacuum only involves Freon, not transmission fluid
The A/C and Transmission lines are separate.
I had a shop installing the condenser including vacuuming and recharging my AC system as it leaked it all out 80$, the part was like 170$ But didn’t have to come out of pocket for any of it. If I would of had to paid still seem like a reasonable price. 700$-1200$ I would of probably kept looking for a different shop
That's right. The ac and transmission lines are separate, but the transmission cooler is in the condenser so it is good to add 1/4qt of fluid just to top off the condenser.
I added fluid to the new condenser from the old condenser, as my transmission fluid had just been changed a few months earlier.
I saw no need to go buy a quart just to use some of it when there was already fluid from the factory condenser that would work fine.
I have a 2015 LTZ Z71 with 41,100 miles and seems like I am leaking refrigerant from the condenser. Really sad that this truck is having these kinda issues and of course, no help from the dealership. Warranty expired May of 201920190827_181648.thumb.jpg.05d2435b81b21ff5d766bb8cf9fd7665.jpg
Same spot mine was leaking from I bought a aftermarket condenser price “179$“ , vacuum and recharge 80$ With installation, AC IS ICE COLD AGAIN ? ❄️
hope u get it fix man I know it sucks having the windows down too damn hot out here especially over here in Texas not sure where your from.
Yup, I'm located in corpus so its definitely too hott!!! Prolly attempt to do the repair myself, great prices from rockauto but do I purchase OEM ac delco or go aftermarket?
Oh I went aftermarket just cuz I got it for really really good deal “free” lol my mother law works at auto parts place so I didn’t have to come out of pocket, I think the OEM just has a piece of havc tape on the corner area where it tends to leak at kinda like a heat shield.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,405 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
