Very disappointed... this is a truck... 150 watts is useless... I really fail to understand how the designers could sit around a conference room table and think adding this feature to a truck was a good idea.Might be good for a small car but not a truck! Give us 15amps at 120volts  or go away. Just dumb.
Because it's something that at least a few people could and do use (150W outlet).
Your 15A/120VAC outlet basically requires the plow package upgrade, as would require AT LEAST 150A (more due to losses converting DC to AC).  And using it, you either get a dead battery pretty quickly, or you need the truck running AND the motor revved up so the alternators are working at close to their maximum output.
That costs a bundle of money to put in every truck, when the majority of people will make do with the low power outlet.
I use mine to on my air mattress pump when I go camping. I also use it to charge my Milwaukee power tool batteries and my laptop.
I have never had it not work for me. But then again, I am a reasonable person. The people that expect this to work like a job site generator are crazy.
I occasionally use the outlet to charge the battery for my RC crawler while I'm driving.  If the truck is parked, I connect the AC/DC charger directly to the battery, since the outlet turns off when the key is out.  I'm only charging at 5A, and around 8V.
47926877338_8d5086a1f6_c.jpgIMG_2690_edited by Ryan Jakob, on Flickr
You can change it so the outlet stays hot all the time.  You need to move a fuse from one position to another (I think it's from space 10 to space 11).  Check your manual or search these forums for instructions.  I did it to mine years ago and use the outlet all the time now.
Good to know, thanks.
I'll still continue to connect direct to the battery when not driving the truck though, for a couple reasons.  First, it's more efficient.  There is no need to convert DC to AC, then back to DC.  Second, I don't like to leave a LiPo battery charging out of sight.  While I consider the risk to be very low, it's not hard to find a few tales of batteries bursting into flames when charging.
  • 4 months later...
Not enough juice to power a power tool battery charger. Anyone know if it can be upgraded for higher wattage?
Well a little math and it looks like  1.3 amps on 115 volts and I assume thats continuous  rated so you might get a little more out for a short time.  Certainly not enough for a crock pot, your table saw or microwave.
I am assuming there is an inverter someplace that could be upgraded to perhaps 500 watts. But your going to draw a lot of 12 vdc amps to do 42 or so and thats not figuring in the loss in the inverter which could add  20%, just guessing.
Edited by wmgeorge64
  • 8 months later...
on my 2016 I just used it to bower a craftsman 1/4 sheet palm sander, when first plugged in it worked for a second or so that failed. unplugged it waited a couple of minutes truck running, plugged it back in with the green light on bright and it worked long enough to complete the sanding job, That too about 30 minutes.
I've charged every electronic device imaginable with mine. I also plug my Ryobi 18 volt six pack charger into it from time to time. I also regularly run my electric shaver from it with no issue(other than ground up whiskers in my perforated seats).
I sold a table saw to a guy a few years ago(3 HP). I met him in the parking lot at the local grocery store. He pulled out a 100 foot long extension cord and plugged it into the dash. I told him it wouldn't work but he tried anyway. He insisted the saw was bad until I plugged my electric razor into his truck and it worked. I was a bit baffled myself because I though he blew a fuse. Apparently there is some sort of electronic protection in there.
There's definitely some protection in there, I'm no electrician so i can't explain what kind lol.  After running a blow up air mattress and a jig saw on mine I brought a coffee maker to the camp site.  Was real sad when I had to pay for coffee at the general store, but didn't blow a fuse after trying the coffee pot 3 or 4 times ?
  • 1 month later...
I have plugged in a small compressor to this outlet and it didn’t have enough power to run the pump. Pump just made a weird noise and I unplugged it. I am now getting a sluggish start when it cranks over and a couple times now the battery acts as if it’s dead and won’t start the truck, needs jumped. I have had the battery tested (it’s a high output gel battery) and it still tests fine. Could it be a relay that is bad draining the battery when it’s parked? And if so where would it be located? I would think the inverter has to have a relay or module somewhere.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
