If his oil level was too low, he’d be getting fluctuations; the gauge would be moving up and down while at a steady RPM. Check engine light would come on and the fuel pump would be shut down to kill the motor.
O.P., save yourself a trip to the dealer to be told that it’s fine. You’re good for sure.
He’s better off going to get it checked out this way at least he’ll be good to go either way. Besides, you going to fix for free if anything does happen? Don’t think so
I plan on making a appointment for the dealer soon and have them look at it. Just for peace of mine, but I don't think they will do any thing. Plus my factory trailer brake controller don't work when I tested it on my father's trailer
I just looked the information up on alldata and min. Oil pressure is 22psig at 1000 rpm , 30 psig at 2000
Also if you feel you would like another opinion, hook up a mechanical oil pressure gauge and I bet you’ll find it’s actually higher than what yours reads.
In all seriousness, your vehicle is still under warranty, go get it checked! [emoji125]
Tailor the truck to your needs, dial the engine to your needs. If your desert driving,towing uphill 0w-20 ,Just ain't gonna give you the protection your looking for. Millage Really Towing? 5w-30 for a starting point. . Any of these trucks showing pics of there Oil Pressure Gauges thinking they are accurate gauges , crazy ,not much better than old school dummy light.
My 5.3L has always shown 30psi or 1 needle under 30psi at hot idle in FL. Even when it's 99 outside.  Could be the oil if you had a shop or dealer do it.  I would be curious if you did your own oil change with PP/Valvoline/M1 0w-20 what the pressures would be.
Edited by FL335i
My truck has not seen a dealership since I bought it. Did first oil change with mobile 1 020 at 700 miles and been every 5000 miles since
So much for that theory.  I'd take it in and if they say "it's normal".  Then ask for a print out of the GM Service Manual that provides the oil pressure range spec.
On 8/15/2018 at 1:59 PM, Coolboatguy said:
I have not logged temp, but I'm sure its probably scalding.   Normal low for me is 12psi.   This is just the lowest I've seen and probably is from the high temps and thus the only reason I took a picture.   According to dealers 6psi is the minimum so apparently they don't care about anything above that.  The corvette boards recite roughly the same.  It should be noted that mine is a rebuilt motor as well and I'm more interested in whats normal in case I want to take it to the shop I had it built at.  Some say cam bearings could cause this as well as an oil pump.
I looked at other sites and they confirmed the use what ever oil weight that gets you 10 psi/1000 at 212 degrees reasoning.
I dont believe the trucks support the oil temp feature. I use HPT as well, my truck never shows oil temps but my 2017 Camaro SS does. Same engine in both vehicles.
Part of the issue is the 0w20 oil, that is used for trying to improve the corp fuel mileage numbers and that reason only. Anything the manufactures can do to tweak out some more MPG. Junk that stuff and either run a 0w30 or 5w30 if you are going to tow.
Second, the oil pumps in these engines are dual stage. So they have a low and high mode in them as well, again to help with EPA numbers.
They do, you just need to set up the software to scan for it.  I read engine oil temp with both HPT and Torque on Android.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
