Just installed my Rough Country grill inserted dual 10" light bars! Looks amazing and the light output is pretty solid for a couple small bars. Very clean look and the instal wasn't overly complicated at all.
  • Like 8
On 11/10/2019 at 10:19 PM, BlackLS said:
Installed Rough Country Flares.
how do you like and where did you get the deflector/light bar thing on the hood?   looks nice!
What button?  I thought you had to go into the menu to disable it.
Ryan B.
Got GM accessory fog lights wired up and activated.
Installed Tyger Star Armor side steps.
Motofab leveling kit came today (2” front and 2” rear) but can’t get it installed until Friday.
Edited by Method2Madness
  • Like 6
Looks great! Can you post a pic of where the toggle switch is installed?
I’m having mine installed in a week
Installed a wire tap kit for my radar detector. Very easy!  Removed the Texas Edition badges and installed a set of Weathertech splash guards.
Edited by Texasdeere
Sure thing! I didn't take a photo of it, but I can this evening or in the morning! It's just double sided tape so I stuck it right by the hood release. The tape doesn't seem to be the best, so I may need to re-do it with some stronger 3M.
Thanks, it is a Auto Ventshade 753168 Aeroskin LightShield
I like it, lights are very bright and it was an easy installation.
On 11/12/2019 at 6:40 PM, NCD said:
Thank you sooo much for posting this!!!! I am about to pull the trigger on the rough country flares. I had yet to see them on a black Silverado and man it looks awesome!
any way you could take a pic directly from the side?
5% tint all around,  I also installed  Bak revolver x4 tonneau ,  wireless qi charger in console lid with its own usb power source. Auto stop/start harness , led reverse lights and now rough country Grille lights . I was busy yesterday!!
Brian
Brian
Does it improve your lighting??? Here in moose country it would be a nice add on. Thanks for reading!!!
Got the Motofab leveling kit installed today. 2” front, 2” rear. Love the difference it made.
first pic with the tree is before
 second is after.
It Makes a HUGE difference! trust me you will not be disappointed.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
