1 hour ago, mdf21 said:
Got the 3.5” RC lift kit installed on my ‘21 Denali. Should help with the ground clearance hitting the woods and the ride is just like factory
Nice! If I may ask, what size tires are those? Any rubbing?
Thanks. 275/60R20 same as factory.   No rubbing at all
Thanks for the quick reply. Are you perfectly level with the RC kit? Or do you have a little rake?
It’s pretty close to level with just a tiny bit higher in the back. Here are my before/after measurements to the wheel well:
Before
Front left 36.5     Front right 36 5/8
Back left 39         Back right 38.5
After
Front left 39.25     Front right 39.25
Back left 40.5         Back right 40.5
Before
After
Thanks. Did you adjust your headlights?
I haven’t messed with them yet but two trips in the dark after the install and I haven’t been flashed by oncoming traffic yet so it’s either not too bad or the shop adjusted them already.  I’m gonna keep an eye on it and adjust if necessary
Added a light kit to the multi pro tailgate. Got this one on Amazon vs the GM kit at half the price and larger LED modules
  • Like 6
  • 1 month later...
Last week I was finally able to finish the wireless charging addition to my truck.  Had to switch the wire harness so that I got the factory navigation working in my truck again.  Figured I'd take the time to get the project done right and added the air duct tube that goes to the wireless charging pad.  That was a PITA due to having the Bose system.  Also had to pull a blend door actuator to get the tube installed by the lower glove box.  Everything is working as it should now.
Today I finished my custom wiring of the Rough Country grill lights to the GM Upfitter auxiliary switches.  I really wish GM had pre-wired the auxiliary switches into the truck like Ford did for the Raptor.  Connecting to blunt cut wires under the hood instead of trying to shove everything through a tiny hole in the firewall would make everything so much easier.
I got rid of it!
And FINALLY got its replacement. The 2021 I ordered (same specs) has been sitting in an overflow lot in Roanoke IN since 3/17/21 so I ordered a 2022 with the exact same specs and look what came in first LOL This is our new development vehicle a 2022 Denali Ultimate CarbonPro LM2; also my first diesel and so far I'm LOVING IT. Definitely a different driving experience over gas but so far even with like 100 miles on it the fuel economy is insane as is the torque.
At any rate it stayed stock for about 50 miles (this likely wont surprise any of you) first mods were WAMS Custom BCM programming (fogs with high beams, windows up from fob, remote start run time increase etc the usual stuff), WAMS Custom High Country Cluster to replace the Denali cluster with GMC graphics (lets be honest it looks better than the Denali unit lol), auto cooled and heated seats/wheel and an AutoStop Eliminator. Next up I'll be swapping in one of our wireless CarPlay kits to get HD radio back then after that maybe screw around with the rear heated seats LOL
  • Like 3
Detailed the inside today, just needs a wash and wheel spray.
Putting wheel skinz on my 1500 today.   I've had them before on other trucks, but these are by far the best fitting I've had.  On past ones I've seen a slight bit of the rim, but with these you cannot see any of the rim underneath.
What ya guys think?   I have to get black center caps.   I can't decide if I should get chrome bow ties or all black.  My lugs are steal / chrome.
only had the truck for a few days and already put wheels n tires on it...
RWD Silverado.
Vision Turbines 17 x 8.5 +18, Cooper ATP II 265/70/17
I think they def compliment the color of the truck...
Nice!
My first thought is all black center caps, but If your keeping the chrome lug nuts, I'd go with chrome bowtie.
Do you have a link for those wheel skinz?
1 hour ago, bdallas said:
Nice!
Thank you!!    It's much easier and better looking than dipping them.  Plus they don't scuff the rims.
Here is the link:
https://www.ebay.com/itm/Set-of-4-20-Wheel-Skins-for-2018-2020-Chevy-Silverado-Gloss-Black-/265069670261?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=711-127632-2357-0
Looks great!  I'm partial to all black and even got the lug nuts from GM Accessories to get rid of the chrome.
19 hours ago, GTPprix said:
I got rid of it!
Congrats!  Even after owning my truck almost 18 months I have a love/hate relationship with the engine.  I love the power of the 6.2, but hate the fuel expense.  $5/gallon for 91 (closest to 93 you can get in California).  Diesel is cheaper that regular.  However, I know that no matter what I had gone with I would've not been 100% happy.  I do wonder what it drives like though.  Never got a chance to try out the diesel (nor any of the engines) before buying.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
