1 minute ago, Bluerado23 said:
Ran these for a few days and liked the look
22” wheels off premier Tahoe.
Looks nice. A member here had the same 22" wheels on his Sierra and after a few thousand miles he removed them to check and the caliper cut a groove on the back of his front wheels.  Here's a pic of his truck.  I'll try to find the pic of the groove cut in his wheels.  Just FYI.
Thanks I appreciate it, yeah I had to use a 3/8 small spacer to fit the front cause they wouldn’t even rotate one bit.
But they’re gone now, only had them two days
A spacer clears the caliper but now the bad thing is your truck isn't hub centric anymore and is now lug centric.  Gm trucks don't like to be lug centric.  The max spacer thickness that can be used is 3mm (1/8") to remain hub centric.  There's only one place I know that makes a 3mm spacers for these trucks.
It did look good.
Same wheels, different tires that came on my Centennial Edition.
On the sierra's if you want to run previous  model 22'' wheels you need spacers,looks like the calipers on the Sierra has a small tab on the face of caliper that the Silverado does not have.
some people just grind that tab.
I will try to find the video that the guy was showing  and explaining that there is a difference in the calipers and showing the tab on the gmc caliper.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
