At the ranch helping with some cattle panels, shots for cattle, and tagging the calves. Just a little rain and some mud on the tires.
Found this site few days ago while trouble shooting a problem and figured I'd post my 2020 1500 sierra AT4 with 5.3 little over a year old. Has the multi-function tailgate and Kicker sound system. I had the bug deflector and rain guards along with the tonneau cover added at the dealership. 15 months old and only have 7,900 miles 👍
Really loved my '15 All Terrain SLT but needed to upsize to a crew cab so the kid has more room. Had to travel to a neighboring state to find this AT4 that was just delivered and somehow was still available. Loving the 3.0 torque and sound!
  • Like 3
First time truck owner here! Got my Silverado last month and loving it! took the fam up the mountain to play in the snow!
Recently got 35inch Toyo Open Country ATIIIs installed on the truck. No rubbing even off-road.
Truck is the 3.0L Duramax RST package with a few upgrades.
Edited by tomthetrex
  • Like 3
Picked up a new(to me) 20 Texas Edition RST on friday. The previous owner swapped out the stocks for high country wheels, along with a nice magnaflow catback. Loving it so far!
Edited by krackkkk
Inspired by the gray one 👆
Here is a pic I put up in another thread.  In a few days I'll have had her for a year and a little over 18k miles.
21 RST, 6.2, GM Performance Intake/Exhaust, powdercoated exhaust tips black, debadged truck, Diode Dynamics SS3 fogs, TRex grill insert and the steps, hardcover, & wheels I bought it with.
Edited by Denali_Joe
On 12/27/2021 at 10:08 AM, PureZ71 said:
Played in the snow yesterday
2021 SLT 2wd. I actually bought it about 6 weeks ago. Really liking it so far. This is my first 2wd in quite awhile.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
